| | | Forums66 Topics128,047 Posts1,055,534 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2002 Posts: 23 Member | | Member Joined: Dec 2002 Posts: 23 | a while ago i saw a thread on refinishing steering wheels and now can't find. i'm keeping the original as it is in very good shape bit the paint is gone in some areas.....suggestions?
1961 Chev 3/4 1977 Chev Nova
| | | | | Joined: Nov 2001 Posts: 275 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 275 | If you have cracks, POR15 epoxy putty. Water soluble. Worked very well on the original from my '56. Then just smoothed with a damp cloth, sanded, self-etching primed, and shot. | | | | | Joined: Feb 2000 Posts: 5,197 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,197 | Mine didn't have any cracks so I just sanded it smooth and used epoxy appliance paint from the local ACE hardware. It comes in black, white, or tan. It sprays real nice and is very durable. Joe | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I am interested in this too. It seems that the old plastic takes on a dull chalky appearance on the surface and I was wondering how paint would adhere. I guess the sanding does the trick. | | | | | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | ace hardware has paint just for plastic. | | | | | Joined: Mar 2003 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2003 Posts: 68 | I have the answer to your problems. S.E.M. Paints make paint designed to use on interior vinyl. It has a flex agent already in it so it will give some. The color you need is called Monterey. It is as close to the proper steering wheel color that I could find without actually buying the paint from Chevy Duty or someone. I think that you will agree when you see the color and the results of the steering wheel. It is not a high gloss though. more semi gloss. I have tried several colors and this is the closest. I even posted a topic months ago on another color. I changed to the Monterey soon after that. | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 |
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Jul 2000 Posts: 580 'Bolter | | 'Bolter Joined: Jul 2000 Posts: 580 | | | | | | Joined: Aug 2005 Posts: 212 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 212 | This is one area on my old 53 that I am really proud of. I'm new to this type thing, and had always been led to believe that repairing a steering wheel is rocket science. It is not. I bought a tube of plastic epoxy putty at the local parts store, filled in the cracks, used really fine sandpaper on the whole wheel, primed it with regular primer, and then sprayed it with Dupont Centari and it looks really great. I used Centari because that is what was used on the rest of the truck, but I'm sure any decent auto paint would work just as well. Try it, I think you will be amazed at how easy it is, and how good it looks.
It might be worth your while to investigate the putty issue a little. I don't remember what brand I had, but it was classified as plastic epoxy. It was a little stiff and hard to work. If you could find something that could be smoothed with water it would make your job a lot easier. Allen | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | Considering that they are hard rubber, not plastic, using plastic products might not be the best idea. Eastwood sells a nice little booklet on steering wheel repair. | | | | | Joined: Mar 2001 Posts: 629 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 629 | Here's an article I found some time ago on restoring steering wheels........ Steering wheel restoration article
Tim Sheridan 1947 First Series Chevy 1/2-Ton"Liberty Series" - "Art Deco" - Whatever you'd like to call it. In the Gallery | | | | | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | Tim, can't get to your site... is something down? | | | | | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | Say Larry, read your post about your steering wheel project... how's the paint holding up since then? What kind of paint is your finish coat?? | | | | | Joined: Jul 2000 Posts: 580 'Bolter | | 'Bolter Joined: Jul 2000 Posts: 580 | Paint is holding up well, Larry. Two or three hairline cracks too small to worry about yet have developed (you don't notice them unless you are looking for them). The paint is Rustoleum "Grass Green" enamel. Whenever I get to the interior phase of my detailing cycle (about once a year), I remove the steering wheel and, after cleaning, give it a light sanding and a refresher coat if it looks like it could use it. | | |
