1 members (Bill Hanlon),
167
Mod | | | Forums66 Topics128,196 Posts1,057,386 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Can’t recall the exact conversation or when I saw it, but there was some reports having to do with the need to rework the Fenton headers being pushed at us today. I’ve been helping a friend get his truck back on its feet and yesterday we tackled the manifolds on the ’56 235 that’s in it. He purchased a complete exhaust kit from National Chevy Assn., which supplies William’s headers with the kit. The bottom line read, “Complete with all necessary hardware and installation instructions.” Now sitting on the bench and hanging on the side of the engine, these, like the Fenton headers look real sharp, however........looks cam be deceiving.
Number one, there were no instructions. Number two the kit did had hangers and muffler clamps but to install the Williams headers without special manifold clamps turns into a real pain in the ars. We made a call to them and the guys were nice enough to talk to but really didn’t have much to offer as far as installation advice. The gentleman that we talked to did say that the headers were made in Ohio and that they used the Fenton headers as a master for the casting. So according to that information the trouble we have with the William’s headers should also apply to the Fenton headers. The trouble: First off, the flanges are cast nearly 1/8” thicker than the stock intake, which sounds easy enough to fix by grinding a little step in the manifold clamps. The way the flange is cast, the front center clamp just barely catch the header by a about 1/32” and only on the top of the clamp. The rear center needs to be ground away right up to the hole and the flange casting actually slightly over-laps the threaded hole in the head. I won’t go into the rest of the individual clamps, but just to say that large amounts of the clamps have to be ground away to get them to fit and the clamping surfaces are then off balanced since the clamp strength comes for the compound curve that is used in its manufacture. The strain bumps in the center gasket have to be flattened in order for the Williams headers to fit flush, this makes the gasket longer and it overlaps the exhaust port by about a 1/16” on both ports, this also destroys the ability of the gasket to act independently on the two exhaust ports and single intake port.
I seem to recall posting something on this subject in the past about the fit of the ‘new’ Fenton castings. Back in the day I’d installed the original Fenton headers and they were a well-made direct bolt on part that required no rework to the castings or clamps. If they have made ‘upgrades’ to the ‘new’ version of cast headers then they should also supply a proper center gasket replacement and newly designed manifold clamps with the header. I hate to have to say this but I’ve had to do less rework from parts that came from across the Pacific than I did to these parts that came for Ohio, USA.
Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | I do not know if the difference in flange thicknesses is a new thing, because I did not use Fenton headers on 216/235/261 engines "back in the day".
The Fentons that I bought in 1997 had a flange thickness that did not match the dual-carb Offenhauser intake. I had to grind the flanges on the Fentons to match the Offenhauser flanges.
The Fenton headers' flanges do match the thickness of the Fenton dual-carb intake manifold (as it should). And, the Fenton headers' flanges almost match the thickness of the original 235/261 intake manifolds (I am using original clamps but they are at a slight angle).
| | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | I know I have had to do extensive rework of many items I have bought for the truck so far. I am just going to consider it part of the fun, rather than going crazy. I had the same problem with the fenton set, I was aghast when I received the intake in a box that had "made in china" on the side. I don't recall where the headers were made, I believe they had been repackaged. I did see a post on this forum, or maybe chevy talk, from some fella that did the importing (at least claimed he did) of these parts. And he was saying the quality was getting so poor that the people that held the license was having the patterns redone. And after the existing stock was depleted. The new revised editions will be coming out. He may have been blowing smoke as far as I know, but that was his story. (or something along those lines) | | | | | Joined: Dec 2008 Posts: 901 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 901 | Wanderer1955 1st (Cecil) ordered a William's complete set up. He's supposed to get back with me when the time comes with his opinion on these. Maybe he will post something on here. I'm starting to lean against getting a set of these.
Brian
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Aug 2013 Posts: 255 'Bolter | | 'Bolter Joined: Aug 2013 Posts: 255 | I'll check my Repro Fentons from Patricks that I recieved a while back. They're not mounted yet. Check them against the Military 302 intake and the "H" head intake flanges that I have. The Patricks Fentons that I got from Patricks have been machined on already, so maybe they prepped the raw Casting to match the old intakes or maybe it was just to fit a GMC engine. Will post pics tonight. Jim | | | | | Joined: Jul 2013 Posts: 200 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 200 | I'll check my Repro Fentons from Patricks that I recieved a while back. They're not mounted yet. Check them against the Military 302 intake and the "H" head intake flanges that I have. The Patricks Fentons that I got from Patricks have been machined on already, so maybe they prepped the raw Casting to match the old intakes or maybe it was just to fit a GMC engine. Will post pics tonight. Jim The Fenton's will only bolt onto the Stovebolt cylinder heads out of the box, and they require extensive port welding and grinding to adapt to fit a GMC port arrangement. Also keep in mind that Patrick's has been the only one to ever have permission and a trademark agreement to us the Fenton name, and everyone else is basically stealing that right away from him in selling knockoff parts under the Fenton name.
We cannot solve our problems today using the same thinking we used when we created them! Albert Einstein
| | | | | Joined: Mar 2000 Posts: 1,184 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,184 | I have original Fenton headers that came off a 55 235 and an Offy dual 1bbl intake. The flanges matched up fine. So the originals work fine with a "modern" manifold. Maybe the repro guys aren't paying close attention to the specs or have sloppy production practices. | | | | | Joined: Aug 2012 Posts: 566 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 566 | I will say i do not know how the originals were made back in the day so i can only tell you about my experiences about todays knock offs. I expect That when I order reproduction products I'm going to have to do some refitting because they just don't fit right. My experience with the Fenton headers and intake I had to do some modifications to them also. I thought they would match right up to my 235 head However At the ends of the heads I had to build a bracket Because the Fenton headers Mounting tab was a lot higher than the one on the intake. Now in all fairness Don't know who is really at fault. I bought the intake from Patrick's And the headers of ebay. Wasn't a big deal I figured I'd do some work on it anyway. Now the thing that really shock to me The intake from Patrick's that I bought I did not notice it until after I had it power coated When I set it down on the table and I noticed that the ports were not at the same height I looked online and looked at other intakes already installed in the motors and they all seem to the lean to the front of the motor maybe it's designed that way but I would think that it would level. As far as mounting the two Fentons to the head i just made it work. And if it's wrong I will go back and find out what's wrong and make it work. But you guys are right it doesn't matter what body panel or what engine part and knock off it should be right. Secondly one of the stoveboulders who lives in Germany bought his Fenton intake from Patrick's and when he got it home. He noticed that there was a hole in one of the intake ports he sent me the picture of it and it looked like you could have dropped a dime into it luckily he was able to to weld it and repair it. http://i1291.photobucket.com/albums/b554/stovebolt56/20140204_2042261_zpsnxd7it7d.jpg I guess it is what it is and you gotta do what you gotta do. I still love working on this old iron. I am still a happy bolter doing one piece at a time.
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my sweet ride." -Amen 56 Chevy 3100 | | | | | Joined: Feb 2012 Posts: 84 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2012 Posts: 84 | FWIW I've got a set of Williams I ordered last year, bolted to an 838 head on a 55 block on a stand in my shop for a future project. Using an Offenhauser 216 dual carb intake it bolted right up using a set of stock clamps. I did do a little hand filing on the center exaust extensions back sides to remove a little angularity in the clamp, but it was just a few minutes work. The faces were lovely, machined flat and parallel. I liked 'em.
I vaguely remember hearing somewhere that the Offy was their intended set up, but cannot confirm. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | My Fentons were supposed to be machined for a GMC too. All I could see is they machined a flat spot and stamped GMC into it. It took extensive work to get them to fit. A better deal for GMCs, though more expensive, is the Nicson headers Buffalo sells. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | There is simply no way that you could use the stock manifold clamps without, as Charlie puts it, "extensive work". If I had my Bridgeport set up I'd just machine a set of custom clamps because by the time you grind away the stock ones there is hardly any decent clamping surface left on them. We're using the stock intake manifold on this truck, still, even if the headers were matched an after market intake that wouldn't change the way the headers are cast, which is right in the way where one needs to clamp them up. Chuck, I'd really like to see some pictures of your William's headers that you installed on your truck, since you say they mounted right up without a hitch.
I have to disagree with those that expect to modify everything that we buy for these trucks. For the kind of money that we're shelling out something like this should be a direct bolt on item, without any modification or at least with replacement clamps that would make the install solid.
DG
| | | | | Joined: Aug 2012 Posts: 566 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 566 | DITTO'S Heres what I did. I saw it in a book, bought the angle iron and started modifying. Rear Front Finished product
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my sweet ride." -Amen 56 Chevy 3100 | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Aug 2012 Posts: 566 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 566 | Your welcome Tim. I actually read it from The Classic Chevy Truck Handbook on page 38 written by Jim Richardson. The illustration in the book looks better than mine but I am still pleased how the came out. I tried every which way to grind and make the others work but they did not look or fit right. I am glad I read about that
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my sweet ride." -Amen 56 Chevy 3100 | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Yep, that looks like the only way to get them to fit, make your own. Obviously the after market intake is different than the stock single manifold. The stock center clamps won't work without heavy grinding and in some cases they aren't long enough to span the two flanges, only grabbing them by a 1/16" or so.
DG
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | To continue this conversation, I would like to see some pictures of the passenger side pipe where it crosses under the transmission. The one that National Chevy Assn. sends with their kit blocks off the drain plug on the SM420 and actually hits on it if you try to raise the muffler up level with the driver side. Also the passenger muffler falls behind the driver side by nearly half its length. Tail pipe on the passenger side had to be cut off and re-swaged to fit inside the glass pack muffler. The tail pipe on the driver side had to be extended roughly eight or ten inches to reach the muffler. Denny Graham Sandwich, IL
| | | | | Joined: Apr 2012 Posts: 135 Shop Shark | | Shop Shark Joined: Apr 2012 Posts: 135 | Looks like I'll be keeping my stock single exhaust. After working on commercial lawn equipment for ten hours a day, I would not want to come home and have to make a bunch of modifications to make a manifold fit. To me, that would most definitely not be "part of the fun". I have plenty of other frustrations in life to deal with
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Good choice Ed, I'm not working on this truck, I just started this thread for a friend who is trying to install it. Believe me, what was pictured as a complete dual exhaust kit in the catalog is really a bunch of crap. Manifold doesn't fit right, pipes are bent wrong, pipe ends are improperly made, hangers need additional straps to reach the frame.
50 years ago when I bought my dual exhaust kit from the Sears catalog for my '60 Biscayne it was the original Fenton kit. everything fit well, no modification and it was a breeze to install. It's really a shame what they are selling today. Denny Graham
| | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | I have nothing to add but have a somewhat related question. I currently have a nearly brand new single exhaust system on a 49 3100 216 from manifold to tailpipe. On a conversion to duals, will the stock single exhaust lineup and bolt to one of the dual exhaust manifolds? Tiny, nice mod. Another reason why I wanted to bookmark this thread for future use Dave | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Dave, the dual Fentons are supposed to use one stock pipe. Whether or not they actually do in practice, I don't know. | | |
