| | | Forums66 Topics128,037 Posts1,055,466 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 62 | I found a set of two 235/75/15 tires,will they fit wheel will on my 1948 1/2 ton,on the rear, original rims .Thanks | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The original standard wheels should be 16s. Even if they are the optional 15s, I believe 4" or 4.5" were the widths, they will be too narrow for a 235/75/15, which needs at east a 6" wheel for proper sidewall support. A 215/75/15 would fit better, even then it's pushing the minimum width for the tire.
Bill Burmeister | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | I had originally purchased 215/75/16 for my 49. The dealer refused to install them on the narrow rims. Went for a second opinion and got the same refusal. | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | I can sympathize that not everyone can afford to pay the $92 a wheel for wheelsmith wheels, if you can, its a great solution. Brand new wheels that look the same as your vintage ones, yet have all of the modern symmetrical changes. Things like disc brakes, modern radial widths, etc. A great idea if funds allow. If not, last time I had 235/75/R15 tires put on my actual vintage 15 rims, I just had Walmart do it. They didn't blink. | | | | | Joined: Aug 2012 Posts: 566 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 566 | When I bought mine from Discount Tire they told me the max for the original rims were a 225/75 R-15 and they agreed with you all that the 235/75-R15 would just be too wide to be safe.
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my sweet ride." -Amen 56 Chevy 3100 | | |
