5 members (Stovebolt48, Rmillerfly, Shaffer's1950, 2 invisible), 93 guests, and 1 robot.
Topics128,050
Posts1,055,758
#1033952 06/06/2014 11:13 PM
I found a set of two 235/75/15 tires,will they fit wheel will on my 1948 1/2 ton,on the rear, original rims .Thanks
oldchevyguy #1033955 06/06/2014 11:28 PM
The original standard wheels should be 16s. Even if they are the optional 15s, I believe 4" or 4.5" were the widths, they will be too narrow for a 235/75/15, which needs at east a 6" wheel for proper sidewall support. A 215/75/15 would fit better, even then it's pushing the minimum width for the tire.
Bill Burmeister
oldchevyguy #1033999 06/07/2014 2:32 AM
I had originally purchased 215/75/16 for my 49. The dealer refused to install them on the narrow rims. Went for a second opinion and got the same refusal.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
oldchevyguy #1034004 06/07/2014 2:42 AM
Gas Pumper
Gas Pumper
I can sympathize that not everyone can afford to pay the $92 a wheel for wheelsmith wheels, if you can, its a great solution. Brand new wheels that look the same as your vintage ones, yet have all of the modern symmetrical changes. Things like disc brakes, modern radial widths, etc. A great idea if funds allow. If not, last time I had 235/75/R15 tires put on my actual vintage 15 rims, I just had Walmart do it. They didn't blink.
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
oldchevyguy #1034029 06/07/2014 7:55 AM
When I bought mine from Discount Tire they told me the max for the original rims were a 225/75 R-15 and they agreed with you all that the 235/75-R15 would just be too wide to be safe.
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my sweet ride." -Amen
56 Chevy 3100
