9 members (Gdads51, 52Carl, Stewart2, Gray_Ghost, Canadian Dump, KEVINSKI, Otto Skorzeny, Southerntruck, BC59),
184
Mod | | | Forums66 Topics128,165 Posts1,057,006 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 423 'Bolter | | 'Bolter Joined: May 2006 Posts: 423 | I've had the front end of my 53 half-ton off the frame during the winter while changing the motor etc. Most everything is back in place, but there is always something left over. In this case I have two supports, about 2 1/2 feet long, holes for a single bolt on each end, somewhat angled at the ends. They look like shorter versions of the supports that stretch diagonally above the motor to the fenders. They are not the shorter ones that anchor the lower rear of the front fender corners. Any ideas where they might go? Thanks for the ideas, I can't understand how I can have forgotten this...
Karl It may not be the easy way, but it is the Cowboy Way - Ranger Doug Beware of the stories you read or tell; subtly, at night, beneath the waters of consciousness, they are altering your world. - Ben Okri 1953 Chevy 3100 1960 Volvo PV 544 1941 Chevrolet Special Deluxe | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Oops, ya out fumbled me by 10minutes Gus, think you done nailed it though, good picture. Just had a friend asking about them also on his restoration. DG
Denny G Sandwich, IL
| | | | | Joined: May 2006 Posts: 423 'Bolter | | 'Bolter Joined: May 2006 Posts: 423 | Yup, those are the ones. How easy will it be to get those in now when the grill is in place? Maybe not too bad if I just take off the upper plate... Karl It may not be the easy way, but it is the Cowboy Way - Ranger Doug Beware of the stories you read or tell; subtly, at night, beneath the waters of consciousness, they are altering your world. - Ben Okri 1953 Chevy 3100 1960 Volvo PV 544 1941 Chevrolet Special Deluxe | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Yep, take the hood latch baffle out and you can get to the upper ones easily. The bottom ones may be a challenge but you should be able to get to them also. Spend a few minutes and get the top and bottom and left and right figured out first, they can be a little confusing.
DG
