0 members (), 112 guests, and 1 robot.
Topics128,136
Posts1,056,425
Members48,441
#1032993 06/02/2014 11:28 PM
I am still deciding what to use to protect the wires from the harness to the tailights. I like the asphalt coated woven stuff because its kinda "old school" but maybe the split type is more practical. Feeding wire that has installed terminals does not look like fun. What is the best i.d. to use?
I'm pretty happy with the plastic wire loom that is readily available in auto parts stores (and inexpensive). It really cleans the wiring up and makes things more "professional", although I am still very much a rookie.
Tail-light wiring
Bob
1954 Chevy 3100 5-Window
1954 5-Window COE aka "THE BEAST"
Bill Ritchie's Original Truck
Granddad's Hardware Store: Ritchie Hardware, Concord, N.C.
Bethesda, MD
Put some heat shrink over the terminals. If possible stagger the terminals. Use a pull wire rather than pushing the wire through. Diameter all depends on number of wires.
I was able to use the 1/4" wire jacket. The two wires from the tail light feed through easily. I installed the terminals after the wires were feed through.
Not too bad for a "rookie" Ritchie. I like those clips on the frame in the last photo. Where did you find those?
That's factory GM stuff, you should be able to get them at Autozone or similar.
Painless Performance, Keep It Clean Wiring, and others now have loom available that looks similar to the asphalt stuff but is split. Have a look at it.
My 46 GMC on Photobucket
Thanks, I'll look into it.
