| | | Forums66 Topics128,141 Posts1,056,488 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | I am still deciding what to use to protect the wires from the harness to the tailights. I like the asphalt coated woven stuff because its kinda "old school" but maybe the split type is more practical. Feeding wire that has installed terminals does not look like fun. What is the best i.d. to use? | | | | | Joined: Mar 2013 Posts: 235 Shop Shark | | Shop Shark Joined: Mar 2013 Posts: 235 | I'm pretty happy with the plastic wire loom that is readily available in auto parts stores (and inexpensive). It really cleans the wiring up and makes things more "professional", although I am still very much a rookie. Tail-light wiring | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | Put some heat shrink over the terminals. If possible stagger the terminals. Use a pull wire rather than pushing the wire through. Diameter all depends on number of wires. | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | I was able to use the 1/4" wire jacket. The two wires from the tail light feed through easily. I installed the terminals after the wires were feed through.
| | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | Not too bad for a "rookie" Ritchie. I like those clips on the frame in the last photo. Where did you find those? | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Not too bad for a "rookie" Ritchie. I like those clips on the frame in the last photo. Where did you find those? That's factory GM stuff, you should be able to get them at Autozone or similar. I am still deciding what to use to protect the wires from the harness to the tailights. I like the asphalt coated woven stuff because its kinda "old school" but maybe the split type is more practical. Feeding wire that has installed terminals does not look like fun. What is the best i.d. to use? Painless Performance, Keep It Clean Wiring, and others now have loom available that looks similar to the asphalt stuff but is split. Have a look at it. | | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | Thanks, I'll look into it. | | |
