4 members (Steelonsteel, klhansen, Gray_Ghost, Bill Hanlon), 54 guests, and 1 robot.
Topics128,076
Posts1,055,924
Members48,430
#1031673 05/28/2014 3:02 AM
I drove my 50 cabover today for the first time and found out that it needs cab mounts, while driving the cab was jumping from the frame. where do I buy new ones? are the truck mounts different from cabovers? thank you Dan
http://s1055.photobucket.com/user/baldybenny/library/
1936 1.5 wrecker,1937 gmc coe,1939 Chevrolet coe,1942 4x4 coe, 1942 coe,1946 dump,1947 2 ton dump,another 1947 2 ton dump,1950 coe,1967 c30,1937 cat 22,1936 Chevrolet 5 window foremans coupe, 1914 ford speedster.
The mounts are not reproduced and they are different from the standard cab I believe? I will repost tonight with more information after I have had a chance to review.
Looking through the FAM (see attached) there is one unique part for the 5000 Series trucks. This is #3703694 the mount bracket to the sub frame. All of the other parts are interchangeable with all models.
https://www.flickr.com/photos/advance-design_parts_co/14302025531/in/set-72157631868452754
This shows a typical 3000-4000-6000 bracket (3100 has a special off-set bracket on the frame side, other is the common #3690029) everything else here will work including shims and anchor nut plate. It would appear the sub frame bracket is a sheet stamped assembly to fit into the unique COE cross frame member. As such it may be fairly easy to fabricate a suitable replacement and then use the parts from the standard cab for the rest.
https://www.flickr.com/photos/advance-design_parts_co/8129510232/in/set-72157631868452754
I have an extra one of those sub frame cross members, should you need it
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
Thank you so much Brad for the info! I now need to dig into it to see what's bad or good and fix it. Thank you! Dan
Spanky, when I get into this and if I need one I will let you know! Thank you! I am working on the 39 COE now and will see if that one runs, Its sure fun to get in the 50 COE and drive it around, I never drove a truck that high up in the sky! I know you have driven these COE's and now I know the feeling,everybody should drive one of these old COE trucks once in there life time! lol Great fun for all! Dan
1 Offline
Hey Brother, try to keep it running so I can experience that this July, it's on my bucket list......Rick.
1936 Chevrolet 1.5-ton SWB
"Murtahg"
More pix on Photobucket
It's only original once.
