2 members (55shaker, Peggy M),
78
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,073 Posts1,055,908 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 402 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 402 | I drove my 50 cabover today for the first time and found out that it needs cab mounts, while driving the cab was jumping from the frame. where do I buy new ones? are the truck mounts different from cabovers? thank you Dan http://s1055.photobucket.com/user/baldybenny/library/ 1936 1.5 wrecker,1937 gmc coe,1939 Chevrolet coe,1942 4x4 coe, 1942 coe,1946 dump,1947 2 ton dump,another 1947 2 ton dump,1950 coe,1967 c30,1937 cat 22,1936 Chevrolet 5 window foremans coupe, 1914 ford speedster.
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | The mounts are not reproduced and they are different from the standard cab I believe? I will repost tonight with more information after I have had a chance to review. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Looking through the FAM (see attached) there is one unique part for the 5000 Series trucks. This is #3703694 the mount bracket to the sub frame. All of the other parts are interchangeable with all models. https://www.flickr.com/photos/advance-design_parts_co/14302025531/in/set-72157631868452754This shows a typical 3000-4000-6000 bracket (3100 has a special off-set bracket on the frame side, other is the common #3690029) everything else here will work including shims and anchor nut plate. It would appear the sub frame bracket is a sheet stamped assembly to fit into the unique COE cross frame member. As such it may be fairly easy to fabricate a suitable replacement and then use the parts from the standard cab for the rest. https://www.flickr.com/photos/advance-design_parts_co/8129510232/in/set-72157631868452754 | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | I have an extra one of those sub frame cross members, should you need it | | | | | Joined: Aug 2012 Posts: 402 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 402 | Thank you so much Brad for the info! I now need to dig into it to see what's bad or good and fix it. Thank you! Dan http://s1055.photobucket.com/user/baldybenny/library/ 1936 1.5 wrecker,1937 gmc coe,1939 Chevrolet coe,1942 4x4 coe, 1942 coe,1946 dump,1947 2 ton dump,another 1947 2 ton dump,1950 coe,1967 c30,1937 cat 22,1936 Chevrolet 5 window foremans coupe, 1914 ford speedster.
| | | | | Joined: Aug 2012 Posts: 402 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 402 | Spanky, when I get into this and if I need one I will let you know! Thank you! I am working on the 39 COE now and will see if that one runs, Its sure fun to get in the 50 COE and drive it around, I never drove a truck that high up in the sky! I know you have driven these COE's and now I know the feeling,everybody should drive one of these old COE trucks once in there life time! lol Great fun for all! Dan http://s1055.photobucket.com/user/baldybenny/library/ 1936 1.5 wrecker,1937 gmc coe,1939 Chevrolet coe,1942 4x4 coe, 1942 coe,1946 dump,1947 2 ton dump,another 1947 2 ton dump,1950 coe,1967 c30,1937 cat 22,1936 Chevrolet 5 window foremans coupe, 1914 ford speedster.
| | | | | Joined: Sep 2012 Posts: 170 Shop Shark | | Shop Shark Joined: Sep 2012 Posts: 170 | Hey Brother, try to keep it running so I can experience that this July, it's on my bucket list......Rick. | | |
