2 members (dt235sd, 1 invisible), 114 guests, and 2 robots.
Topics128,153
Posts1,056,827
Members48,456
My 1950 3100 is coming together nicely. I'm upgrading to 12 volts and still using the original foot starter. I was wondering if this will prematurely cause the starter to fail? It's already older than me but I am not sure if the starter needs to be changed or reworked to handle more voltage?
1950 Chevy 3100
In the DITY Gallery
77 International Scout ll
96 F-150 ext cab 4x4
2000 Tahoe
2011 chevy 3/4 ton 4x4
Ex Hall Monitor
Ex Hall Monitor
It'll be fine. Just don't crank it for minutes at a time. If for whatever reason it doesn't start normally don't crank until the battery dies.
keep it in shape so it starts right up and the 6V starter will do fine on 12V for almost ever, as long as you don't grind away at it for extended periods
Mine's been running this way for years with no problem, but yes, do not over extend the cranking.
Craig
Same here. Starts almost instantly.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
One thing about putting 12 volts to the 6 volt starter is that it turns the engine at a much higher rpm than it would on 6 volts. This causes the engine to start much easier. If your 6 volt starter on 12 volts does not start your engine before you heat up the starter, you have a serious engine problem requiring attention unrelated to your starter.
