Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
1 members (Shade Baby), 132 guests, and 2 robots.
Topics128,283
Posts1,058,505
Members48,490
Page 113 of 177 1 2 … 111 112 113 114 115 … 176 177
cleaned and prepped that 72 year old 216 engine for paint.
Finished installing my seat belts that I stated on Sat and rebuilt the drag link
Replaced left front spring. Shot some rust buster on nuts holding right spring and will try again tomorrow. Baby steps
Got my fresh 235 in and took first maiden voyage today. What a difference from the 216! WOW! I'm in heaven. Got vacuum and timing set nice. Got my Langdon dual webers tuned, Williams headers sound nice! Have nice rat tat tat on acceleration. Got my dual pies straight out back, just finished clamping them today. Look Awesome!
Going to take some pics...
I love this site! While I don't ask a ton of questions, I have found the search option very, very accommodating! Thanks all, Phil...
Phil
Wow, lots of work got done this weekend. Cool.
Going thru the brakes on my 45 1.5 ton. Replaced the right front wheel cylinder. Found a pinhole leak in the brake line crossing to the left front. Replaced that line. Had the rocker cover off, put new hats on the valve stems (thank you Pre 68 Dave!). Replaced a leaky oil gauge line.
Put everything back together, cranke 'er over, was rewarded with an awful squalling sound, a fwap and thump. Lord, I've somehow blown up my babbit pounder 235!
No, failed to notice that the brake leak had been spraying up just in front of the generator. At least, I think thats what caused the poor things bearings to seize up. The fwap thump was the belt letting go. But I had an extra generator in my box of extry parts, so thats on now, go hit the MFA for a belt tomorrow.
1945 1.5-Ton Chevy Big Bolt
Maynard
More pix of the old truck
Drydock, if one brake line rusted through the rest can't be far behind. You ought to replace them all.
I just finished adjusting the rear brakes on the Suburban. While doing that I noticed the backing plate bolts were loose. I had to pull the drums to fix that. It's always something.
Rebuilt my spare 6 volt starter.
Painted my new bed sides and tailgate while it was pouring down rain. Back when I first learned to paint, this was considered a no no and I stilled believed that to be true. But the weather forecast in Austin is rain/high humidity for the next week or more. Did a little research on the web and decided it would be ok. No apparent ill effects and most importantly, no dust or bugs! I might have to paint in the rain exclusively from now on. I allowed extra flash time between coats.
This weekend I removed all brake drums and backing plates- cleaned and painted them. Installed all new wheel cylinders, new brake lines hard and soft new shoes and got new E brake/ connection hardware installed. Repacked front bearings as well as cleaned up some of the front end components- I tried bleeding brakes- one fitting leaking. ( also new MC installed last week or so ago) I hope to get that buttoned up this week so it's back on the ground and ready to roll. About 40 hours put into her this weekend.... smile
1954 Chevy 3/4-Ton Chevy
"Mo"
1948-53-54 "Mixed Bag" Chevy Stakebed
"Basket Case"
1952 Chevy 3/4-Ton
"as yet un-named"
Lots of pictures
Got the new belt on, fired right up. Drove it down to the MFA and picked up another new tire. 2 more paychecks and I'll have a full set of 6!
Replaced all the lines last year. A clip came loose and allowed this line to rub now and then on the balancer. dang not me
Maynard
I changed oil and filter and adjusted valves on the Suburban.
I got my hood painted! That,s the last big part. I will rub it out next week. I also installed my grill guard and outer crank support. I installed the wiper arms. Next the silver and red pin stripe. Then I have an appointment for inspection and title. It should be on the road in three weeks! Yupee!
Great news, GW!!!
All I got done was moving parts around to make room for a honey do project. Hopefully, I'll knock that out before the weekend.
What a busy weekend on the truck! Installed an hei in the 235, built and installed a complete pcv system so no more dirty down draft, replaced all soft gas lines and installed a gas shut off valve so future gas filter replacement will be mess free. Also fabbed up a timing marker on the balancer to make future timing easier. In all a LONG but productive weekend!
started stainging the bed wood! Gonna look GREAT!
Originally Posted by DennisM
Nice work on the doors John. What color is that green?
Dennis
I don't know that it has a name. I picked it out of a catalog at the paint shop for the Nason paints.
Here the codes for the paint
I shot it at 8:2:1 (paint/reducer/catalyst)
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
Heater repainted with hammertone paint ready to be installed, as soon as it quits raining up here so I can paint RustBullet on the interior of the cab.
http://s1281.photobucket.com/user/d...%20remover%20experiment/Heater%20rebuild
1950 Chevrolet model 1434 5-Window Canadian manufactured 1-Ton with Dump Bed / Hoist
You will never stop learning new things, no matter how old you are.
went through the tranny, cleaned and painted......got to get that motor painted this weekend
Took the rear fenders off, and got the bed all unbolted and ready to lift off. Next will be taking the running boards and front fenders off. Sorry that I won't be driving it for a while, but if I don't take the first step toward getting the body in good shape, it'll never happen. Today was encouraging, because removing the fenders and bed was relatively easy!
1938 Chevy 1/2-ton
More info in the Gallery Forum
She looks good at 50 yards, and 35 miles per hour, on a dark night.
Originally Posted by mobileortho
A nice smokey burnout!! grin
I love those drive
broke my other door window due to no seals in doors should have learned on the first one. so I got to order some new windows and all door seals this week. should be hear by Friday.
Got the trailing arms reinforced and frame coated with POR15 and then primed. Making progress and having fun dance
https://www.dropbox.com/sc/sm0nachg1ea79h1/AADz_HScb7Kx8hRCcKe1QrJ_a
I got some body work started on thr back cab skin. I also sand blasted the 6 lug hubs and drums that'll soon replace the 3/4 ton stuff.
Tim
1950 3600 Some Pictures
1951 3100
1952 3100 Some Pictures
Completed bed assembly/install. Here is a photo of the first piece of Ipe installed. I thought I had a photo of the complete bed, but don't. Will have to get that this evening and edit post tomorrow. Getting closer....
Photo of completed bed wood. Unfinished Ipe.
Finally got the gages put back together with new face decals on the cluster, new head unit in the speedo, and new gaskets and trim rings for both. Progress!
1947 3100 Advanced Design
Never, never, never, never give up. - Churchill
Got the corner windows in, gas tank painted and installed, started replacing motley collection of hardware with the right clutch-head parts. I hope to get the engine installed in the next week or so.
http://lymanhall.smugmug.com/Trucks/1953-Chevrolet-3100-Truck/i-RvLCbjc/0/M/Truck-M.jpg
http://lymanhall.smugmug.com/Trucks/1953-Chevrolet-3100-Truck/i-zC6gKmj/0/M/Engine%2053-M.jpg
Gotta say a big Thanks! to Brad (ADpartsman) for the great hard-to-find stuff he has sent my way.
1953 Chevrolet 3104 1/2-Ton
More pix
Started to sand the rear fenders. Lots of Bondo to remove! Looks like some PO had clumped it on but never finished. The fenders really aren't in that bad shape under all the mud.
1938 Chevy 1/2-ton
Stained all of the bed wood (at least the tops, have to go back and do the bottoms next, then its time for some parring. Also started cuting out the inner cowl on the passenger side and replacing that... what fun...
got a original radiator for $60 with no leaks yesterday, cheaper than getting my old one fixed!!! grin
Indy wink
1949 Dodge Coronet
1955 2nd Chevy 4400 1.5 ton
1955 2nd Chevy 3100 1/2 ton
1957 Chevy 5400 LCF 2 ton
1966 Dodge D100 Sweptline
1968 Chevy P20 stepvan
1969 GMC LWB pickup
1972 GMC Sprint
1974 CP30 shorty bus
Don't forget to coat the ends, a particularly important spot to prevent rot. I always set the ends in whatever i'm using overnight to let the stain/clear soak in real good.
~Jim
I replaced the shocks on the Suburban and they fought me all the way. Also lubed the chassis while I was under there. Took me 4 hours to get 'er done.
Got my new 235 started for first time. New el system too, needed a bit of troubleshooting but now everything works except the blinkers. Horn works, gauges work, lights too. The 235 has a bit of extra pep!
Karl
It may not be the easy way, but it is the Cowboy Way - Ranger Doug
Beware of the stories you read or tell; subtly, at night, beneath the waters of consciousness, they are altering your world. - Ben Okri
1953 Chevy 3100
1960 Volvo PV 544
1941 Chevrolet Special Deluxe
More pix
Replaced gaskets in my carbs, all metering blocks and accelerator pumps. Nice and dry now
I took out the 3/4 ton rear end,overload springs and overload frame stops. Then I cleand and checked out the new (to me) '58 Apachie 1/2 ton rear end that is taking it's place.
Tim
1951 3100
Got the hood off,grille out and working on rad support to rad bolts in prep for removing front clip. Going to install Scott Danforths front crossmember. Already have the S10 front control arms ,springs and spindles. Need to install my new bushings in front hardware. Slow going at my age (82) but I am determined to get it done. I will attempt to document the crossmember install as I go with some pics. Would love to hear from anyone else that has done this particular installation.
Weeds
Danforth crossmember guys please PM me with advice on any problems you ran across with this install. Thanks a bunch,
Weeds
Well, yesterday I got a professional safety inspection done. The guy usually does heavy-duty trucks, like Kenworths etc., and said he has seen 2010 trucks with fewer issues than mine. I do have to buy a front brake drum, though ...
1951 3800
-hotshoe
Started laying down the spar on the bed wood.
