1 members (Shade Baby),
21
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 898 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 898 | My neighbor brought home an engine he says is out of out of an old 2 ton truck. Pass side rear has the captain bars, so I assume it's a 261. The number by the distributor is F9I8L. If some one could tell me what this is, then I can pass the information on to him.
TIA. Brian
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | Look for the other set of captains bars on the driver's side to confirm that is a 261. If not, you have a 53 235 originally from a car with powerglide transmission. Not a shabby engine at all, BTW. Full pressure oil, insert rod bearings, aluminum pistons, hydraulic lifters. All you need is an 848 head from a 56 or later 235 and you have all the power that a stock truck needs.
| | | | | Joined: Dec 2008 Posts: 898 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 898 | Tim and Carl, Thank You.
Brian
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Look for the other set of captains bars on the driver's side to confirm that is a 261. If not, you have a 53 235 originally from a car with powerglide transmission. Not a shabby engine at all, BTW. Full pressure oil, insert rod bearings, aluminum pistons, hydraulic lifters. All you need is an 848 head from a 56 or later 235 and you have all the power that a stock truck needs. What 261s had captain bars on the left? I have a '54 261 with only one set. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The Captains bars on the left side are not really visible with the manifold on. They are in the center almost at the top of the block. Picture
See the USA in your vintage Chevrolet! My Blog | | |
