7 members (Hotrod Lincoln, CandoBrent, Forty9, TUTS 59, MikeStone1953, MickeyP, Guitplayer),
161
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,106 Posts1,056,211 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2012 Posts: 96 'Bolter | | 'Bolter Joined: Nov 2012 Posts: 96 | cleaned and prepped that 72 year old 216 engine for paint. | | | | | Joined: Jun 2007 Posts: 134 Shop Shark | | Shop Shark Joined: Jun 2007 Posts: 134 | Finished installing my seat belts that I stated on Sat and rebuilt the drag link | | | | | Joined: Sep 2012 Posts: 20 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2012 Posts: 20 | Replaced left front spring. Shot some rust buster on nuts holding right spring and will try again tomorrow. Baby steps | | | | | Joined: Oct 2012 Posts: 94 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 94 | Got my fresh 235 in and took first maiden voyage today. What a difference from the 216! WOW! I'm in heaven. Got vacuum and timing set nice. Got my Langdon dual webers tuned, Williams headers sound nice! Have nice rat tat tat on acceleration. Got my dual pies straight out back, just finished clamping them today. Look Awesome! Going to take some pics... I love this site! While I don't ask a ton of questions, I have found the search option very, very accommodating! Thanks all, Phil...
Phil
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Wow, lots of work got done this weekend. Cool. | | | | | Joined: Feb 2012 Posts: 84 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2012 Posts: 84 | Going thru the brakes on my 45 1.5 ton. Replaced the right front wheel cylinder. Found a pinhole leak in the brake line crossing to the left front. Replaced that line. Had the rocker cover off, put new hats on the valve stems (thank you Pre 68 Dave!). Replaced a leaky oil gauge line.
Put everything back together, cranke 'er over, was rewarded with an awful squalling sound, a fwap and thump. Lord, I've somehow blown up my babbit pounder 235!
No, failed to notice that the brake leak had been spraying up just in front of the generator. At least, I think thats what caused the poor things bearings to seize up. The fwap thump was the belt letting go. But I had an extra generator in my box of extry parts, so thats on now, go hit the MFA for a belt tomorrow.
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Drydock, if one brake line rusted through the rest can't be far behind. You ought to replace them all.
I just finished adjusting the rear brakes on the Suburban. While doing that I noticed the backing plate bolts were loose. I had to pull the drums to fix that. It's always something. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Rebuilt my spare 6 volt starter. | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | Painted my new bed sides and tailgate while it was pouring down rain. Back when I first learned to paint, this was considered a no no and I stilled believed that to be true. But the weather forecast in Austin is rain/high humidity for the next week or more. Did a little research on the web and decided it would be ok. No apparent ill effects and most importantly, no dust or bugs! I might have to paint in the rain exclusively from now on. I allowed extra flash time between coats. | | | | | Joined: Mar 2012 Posts: 156 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 156 | This weekend I removed all brake drums and backing plates- cleaned and painted them. Installed all new wheel cylinders, new brake lines hard and soft new shoes and got new E brake/ connection hardware installed. Repacked front bearings as well as cleaned up some of the front end components- I tried bleeding brakes- one fitting leaking. ( also new MC installed last week or so ago) I hope to get that buttoned up this week so it's back on the ground and ready to roll. About 40 hours put into her this weekend....  | | | | | Joined: Feb 2012 Posts: 84 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2012 Posts: 84 | Got the new belt on, fired right up. Drove it down to the MFA and picked up another new tire. 2 more paychecks and I'll have a full set of 6! Replaced all the lines last year. A clip came loose and allowed this line to rub now and then on the balancer.  | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I changed oil and filter and adjusted valves on the Suburban. | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | I got my hood painted! That,s the last big part. I will rub it out next week. I also installed my grill guard and outer crank support. I installed the wiper arms. Next the silver and red pin stripe. Then I have an appointment for inspection and title. It should be on the road in three weeks! Yupee! | | | | | Joined: Feb 2008 Posts: 1,122 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,122 | Great news, GW!!!
All I got done was moving parts around to make room for a honey do project. Hopefully, I'll knock that out before the weekend. | | | | | Joined: Apr 2011 Posts: 107 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 107 | What a busy weekend on the truck! Installed an hei in the 235, built and installed a complete pcv system so no more dirty down draft, replaced all soft gas lines and installed a gas shut off valve so future gas filter replacement will be mess free. Also fabbed up a timing marker on the balancer to make future timing easier. In all a LONG but productive weekend! | | | | | Joined: Jul 2013 Posts: 388 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 388 | started stainging the bed wood! Gonna look GREAT! | | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | Nice work on the doors John. What color is that green?
Dennis I don't know that it has a name. I picked it out of a catalog at the paint shop for the Nason paints. Here the codes for the paint I shot it at 8:2:1 (paint/reducer/catalyst)
My Fleet: 19411953195919651966 1953 Willy's Pickup John Vegetarian- old Indian word for bad hunter
| | | | | Joined: Nov 2012 Posts: 96 'Bolter | | 'Bolter Joined: Nov 2012 Posts: 96 | went through the tranny, cleaned and painted......got to get that motor painted this weekend | | | | | Joined: Aug 2012 Posts: 103 'Bolter | | 'Bolter Joined: Aug 2012 Posts: 103 | Took the rear fenders off, and got the bed all unbolted and ready to lift off. Next will be taking the running boards and front fenders off. Sorry that I won't be driving it for a while, but if I don't take the first step toward getting the body in good shape, it'll never happen. Today was encouraging, because removing the fenders and bed was relatively easy! | | | | | Joined: Dec 2009 Posts: 292 Shop Shark | | Shop Shark Joined: Dec 2009 Posts: 292 | A nice smokey burnout!!  I love those  | | | | | Joined: Dec 2009 Posts: 292 Shop Shark | | Shop Shark Joined: Dec 2009 Posts: 292 | broke my other door window due to no seals in doors should have learned on the first one. so I got to order some new windows and all door seals this week. should be hear by Friday.
| | | | | Joined: Dec 2013 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2013 Posts: 54 | I got some body work started on thr back cab skin. I also sand blasted the 6 lug hubs and drums that'll soon replace the 3/4 ton stuff. | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | Completed bed assembly/install. Here is a photo of the first piece of Ipe installed. I thought I had a photo of the complete bed, but don't. Will have to get that this evening and edit post tomorrow. Getting closer.... Photo of completed bed wood. Unfinished Ipe.
| | | | | Joined: Mar 2012 Posts: 240 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 240 | Finally got the gages put back together with new face decals on the cluster, new head unit in the speedo, and new gaskets and trim rings for both. Progress!
1947 3100 Advanced Design
Never, never, never, never give up. - Churchill | | | | | Joined: Aug 2012 Posts: 103 'Bolter | | 'Bolter Joined: Aug 2012 Posts: 103 | Started to sand the rear fenders. Lots of Bondo to remove! Looks like some PO had clumped it on but never finished. The fenders really aren't in that bad shape under all the mud. | | | | | Joined: Jul 2013 Posts: 388 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 388 | Stained all of the bed wood (at least the tops, have to go back and do the bottoms next, then its time for some parring. Also started cuting out the inner cowl on the passenger side and replacing that... what fun... | | | | | Joined: May 2012 Posts: 574 'Bolter | | 'Bolter Joined: May 2012 Posts: 574 | got a original radiator for $60 with no leaks yesterday, cheaper than getting my old one fixed!!!  Indy
1949 Dodge Coronet 1955 2nd Chevy 4400 1.5 ton 1955 2nd Chevy 3100 1/2 ton 1955 2nd Chevy 3100 1/2 ton 1957 Chevy 5400 LCF 2 ton 1966 Dodge D100 Sweptline 1968 Chevy P20 stepvan 1969 GMC LWB pickup 1972 GMC Sprint 1974 CP30 shorty bus There are three things that I've learned never discuss with people: religion, politics, and the Great Pumpkin.----Linus Van Pelt Trying to understand the behavior of some people is like trying to smell the color 9 | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Don't forget to coat the ends, a particularly important spot to prevent rot. I always set the ends in whatever i'm using overnight to let the stain/clear soak in real good.
~Jim
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I replaced the shocks on the Suburban and they fought me all the way. Also lubed the chassis while I was under there. Took me 4 hours to get 'er done. | | | | | Joined: May 2006 Posts: 423 'Bolter | | 'Bolter Joined: May 2006 Posts: 423 | Got my new 235 started for first time. New el system too, needed a bit of troubleshooting but now everything works except the blinkers. Horn works, gauges work, lights too. The 235 has a bit of extra pep! Karl It may not be the easy way, but it is the Cowboy Way - Ranger Doug Beware of the stories you read or tell; subtly, at night, beneath the waters of consciousness, they are altering your world. - Ben Okri 1953 Chevy 3100 1960 Volvo PV 544 1941 Chevrolet Special Deluxe | | | | | Joined: Oct 2013 Posts: 122 'Bolter | | 'Bolter Joined: Oct 2013 Posts: 122 | | | | | | Joined: Aug 2013 Posts: 568 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 568 | Replaced gaskets in my carbs, all metering blocks and accelerator pumps. Nice and dry now
| | | | | Joined: Dec 2013 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2013 Posts: 54 | I took out the 3/4 ton rear end,overload springs and overload frame stops. Then I cleand and checked out the new (to me) '58 Apachie 1/2 ton rear end that is taking it's place. | | | | | Joined: Mar 2003 Posts: 1,132 Shop Shark | | Shop Shark Joined: Mar 2003 Posts: 1,132 | Got the hood off,grille out and working on rad support to rad bolts in prep for removing front clip. Going to install Scott Danforths front crossmember. Already have the S10 front control arms ,springs and spindles. Need to install my new bushings in front hardware. Slow going at my age (82) but I am determined to get it done. I will attempt to document the crossmember install as I go with some pics. Would love to hear from anyone else that has done this particular installation.
Weeds | | | | | Joined: Mar 2003 Posts: 1,132 Shop Shark | | Shop Shark Joined: Mar 2003 Posts: 1,132 | Danforth crossmember guys please PM me with advice on any problems you ran across with this install. Thanks a bunch,
Weeds | | | | | Joined: Jul 2006 Posts: 707 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 707 | Well, yesterday I got a professional safety inspection done. The guy usually does heavy-duty trucks, like Kenworths etc., and said he has seen 2010 trucks with fewer issues than mine. I do have to buy a front brake drum, though ...
1951 3800 Be the change you want to see. -hotshoe
| | | | | Joined: Jul 2013 Posts: 388 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 388 | Started laying down the spar on the bed wood. | | |
