| | | Forums66 Topics128,132 Posts1,056,386 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 423 'Bolter | | 'Bolter Joined: May 2006 Posts: 423 | I'm getting ready to reinstall a motor. First time I've been into the torque tube mire. Preparing to fit those new ball joint shims, I've noticed a ridge along the lower inside of the transmission output socket for the ball joint, worn in by the movement of the ball joint I suppose. I really do not need any bad news just now, but should I be concerned about this ridge? I can't see a solution short of replacing the tranny housing. Karl It may not be the easy way, but it is the Cowboy Way - Ranger Doug Beware of the stories you read or tell; subtly, at night, beneath the waters of consciousness, they are altering your world. - Ben Okri 1953 Chevy 3100 1960 Volvo PV 544 1941 Chevrolet Special Deluxe | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | torque tube mire  If/when an enclosed u-joint went bad, damage could be done to the internal surfaces of the u-joint enclosure. As long as the ridge does not affect the ability to seal the enclosure, the ridge should not be a concern (the ball/seal adjustment technique is described in the Shop Manual). | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Wear on the bottom is a sign that the bell was not adjusted correctly and only wore on the bottom. If the bell is reset correctly there is a good chance it will work fine. Here is the adjustment process. National seal company use make a brass insert that fit on the back of a transmission that gave you a new surface for the bell to seat against. I find them at swap meets on occasion.
See the USA in your vintage Chevrolet! My Blog | | |
