3 members (Woodcmiami, Bill Hanlon, 2-Ton), 108 guests, and 2 robots.
Topics128,109
Posts1,056,258
Members48,437
#1030305 05/21/2014 10:28 PM
I'm getting ready to reinstall a motor. First time I've been into the torque tube mire. Preparing to fit those new ball joint shims, I've noticed a ridge along the lower inside of the transmission output socket for the ball joint, worn in by the movement of the ball joint I suppose. I really do not need any bad news just now, but should I be concerned about this ridge? I can't see a solution short of replacing the tranny housing.
Karl
It may not be the easy way, but it is the Cowboy Way - Ranger Doug
Beware of the stories you read or tell; subtly, at night, beneath the waters of consciousness, they are altering your world. - Ben Okri
1953 Chevy 3100
1960 Volvo PV 544
1941 Chevrolet Special Deluxe
torque tube mire headscratch
If/when an enclosed u-joint went bad, damage could be done to the internal surfaces of the u-joint enclosure.
As long as the ridge does not affect the ability to seal the enclosure, the ridge should not be a concern (the ball/seal adjustment technique is described in the Shop Manual).
Wear on the bottom is a sign that the bell was not adjusted correctly and only wore on the bottom.
If the bell is reset correctly there is a good chance it will work fine. Here is the adjustment process.
National seal company use make a brass insert that fit on the back of a transmission that gave you a new surface for the bell to seat against. I find them at swap meets on occasion.
My Blog
