7 members (Southerntruck, Hanks custodian, Jon G, MRMEROTH11, Gray_Ghost, Peggy M, fonz8261),
101
0
Mod | | | Forums66 Topics128,068 Posts1,055,880 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 181 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 181 | recently the fuel pump diaphragm was leaking fuel into the engine oil. by the time I detected/responded it had washed the interior of the untouched engine in my 52 with the 216 cu with 100k miles. on oil change I noticed a lot of sludge draining. on driving I also noticed better oil pressure and a somewhat quieter engine. tinkering around under the valve cover and with the engine at idle I noticed little to none oiling to the rocker arms. now I'm am concerned about interior passages as well. any thoughts on where to start on the rocker oiling and is my concerns valid. less than a 100 miles on engine since oil change. | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | There are lots of good tips on the oil line to the rocker on your 216. Use the search function and try to get the system clean. Could be as simple as sludge moved to the shaft or closing the lime.
Steve H
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | There often times isn't a lot of oil getting to the rockers at idle although you should see some oozing. With the valve cover off and having run the engine for a few minutes (to give the rocker shafts a chance to fill) rev the engine for a few seconds. If you still don't see any oil exiting the holes on top of the rocker arms it's time to check for blockage. Good luck with it.
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | .... and then pull the rocker assembly off and clean clean clean and use an air hose to blow out the passages. | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | The rocker shafts after time have very heavy interior grease build up. Clean those thoroughly too.
Drew
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | There seems to be a suggestion that the thinned out oil loosened some sludge. On my 216, there is a restriction in the rocker supply fitting under the side cover. Any bit of sludge would definitely block it. Also, your rocker supply is designed so that the overflow dumps out the end of the U pipe. If you have oil running out there than for sure your rockers and or shaft are plugged up. | | | | | Joined: Mar 2013 Posts: 219 'Bolter | | 'Bolter Joined: Mar 2013 Posts: 219 | The trick was to pinch the end of that u - pipe off. that would hold more oil in the rocker shaft so all the rockers got oil. Jay D. | | | | | Joined: Jul 2008 Posts: 181 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 181 | brought engine up to temperature and observed rockers for oiling at a fast idle. each weep hole had a good amount of oil with oil being return out of the overflow tube. thanks for all the good help. | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | If you got oil at each rocker at the weep hole on top you have oil at the shaft. Good. If the flow seems to be too little you can pinch the over flow tube and it will force more to the rockers. I don't think you are in danger of over oiling them, but if I am wrong some one will tell us why. What is your oil pressure gauge indicating when fully warmed up at idle and on the road? 15-20 at idle is good for a 216 and 20 or more tells you that the bearing clearances are good on the road. That 216 will last a good long time if you don't try to make it go 70mph. It was made for work and a slower road speed. I for one can not imagine attempting 70mph on any road from 1920 to say 1960. That would be insane.
Steve H
| | | | | Joined: Jul 2008 Posts: 181 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 181 | thanks Steve; it has a 30 psi gauge and it does tend to run at those pressures you mentioned except during the summer months it may be a little lower. I'm age 67 so it's range is within 10 miles of home on country roads at speeds of 25-40. strangely enough that is where the truck and I are the most comfortable. in the gallery under pete black. | | |
