| | | Forums66 Topics128,156 Posts1,057,021 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 374 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 374 | Does anyone know what bushings I would need for the rear of my '46 half ton leaf springs or have cross reference numbers? Also, if you know the front leaf springs cross reference numbers, I'm sure that will be next.  Thanks!
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | You can look it up at RockAuto... then order there or look elsewhere.
| | | | | Joined: Feb 2000 Posts: 5,233 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,233 | This is what you are looking for, https://www.chevsofthe40s.com/detail/6387/Chevrolet_Shackles_Rear_12ton_34ton.htmlHere is a list of front end parts, https://www.chevsofthe40s.com/dept/Truck/cat/200T/Front_Suspension_Components_Shocks_King_Pins.htmlCheck with all the venders in the links above for price options. The inner piece is threaded and should just unscrew out, either way. Top and bottom are both the same. The ends are held in the shackles by a taper, so a quick rap with a hammer breaks them loose. Be sure to support the truck by the frame rails and only high enough to rake the weight off the springs. Don't over tighten the center bolt, just go enough to seat the tapers and ever so slightly bow the shackle plate. The bushing it self is pressed into the spring and frame mount. In the tech section, I believe there is a tip for making a tool to remove and install them.
| | | | | Joined: Mar 2008 Posts: 374 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 374 | Thanks so much Joe H and CASO. | | | | | Joined: Jan 2013 Posts: 2,237 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,237 | Tee,
Just beware, I ordered new bushings for mine and they came slightly larger then the old holes. I was told to just crank them in, but that just messed up the threads on the bushings. It required me to take the mount into a local machine shop and have the holes drilled slightly bigger.
Just a thought since mine were labeled correctly from chevy of the 40s.
Chris | | | | | Joined: Mar 2008 Posts: 374 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 374 | Thanks for the heads up Chris! | | |
