0 members (),
88
Mod | | | Forums66 Topics128,143 Posts1,056,494 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2014 Posts: 7 New Guy | | New Guy Joined: May 2014 Posts: 7 | Where is the color code located on a 1961 Chevy C10 (Apache) pickup truck? I looked inside the glove box: the back of the glove box seems to be made out of cardboard and there's nothing on the metal glove box door.
| | | | | Joined: Apr 2014 Posts: 62 'Bolter | | 'Bolter Joined: Apr 2014 Posts: 62 | There is a plate next to left vent that has a paint code.
1961 Long Stepside Apache 10, original 235, 4 speed and 3:90 posi totally stock (owned 12 years) 1966 Chevelle (owned 53 years) | | | | | Joined: May 2014 Posts: 7 New Guy | | New Guy Joined: May 2014 Posts: 7 | Thanks jb; never would've found it. There was carpeting glued over it. I'd attach a photo but I can't figure it out right now- it's 721A, pure white.
How'd you get a 4 speed in your Apache? Modified thru the floor board? | | | | | Joined: Apr 2014 Posts: 62 'Bolter | | 'Bolter Joined: Apr 2014 Posts: 62 | What can't you figure out? That is a white truck?
The four speed is an original unit. It has that so called "granny" first gear.
1961 Long Stepside Apache 10, original 235, 4 speed and 3:90 posi totally stock (owned 12 years) 1966 Chevelle (owned 53 years) | | | | | Joined: May 2014 Posts: 7 New Guy | | New Guy Joined: May 2014 Posts: 7 | I can't figure out how to include a photo in this forum post.
I see the code for the exterior (721A), which says it should be pure white. What about the color code for the interior? Shouldn't it be on the same plate? | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | No interior color options, Only one color.  | | | | | Joined: Apr 2014 Posts: 62 'Bolter | | 'Bolter Joined: Apr 2014 Posts: 62 | Hot Rod, On that same plate/tag, do you know what the Trim #'s represent?
1961 Long Stepside Apache 10, original 235, 4 speed and 3:90 posi totally stock (owned 12 years) 1966 Chevelle (owned 53 years) | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | Have you downloaded a Vehicle Information Kit for your 1961 truck? Lots of great data.. here's a link: http://gmheritagecenter.com/docs/gm...hevrolet-Trucks/1961-Chevrolet-Truck.pdfOn the 63-66 trucks "Trim" = the applicable RPO code. Not sure about a '61. Go to page 36 in the pdf I linked above, page "Cabs and Bodies 3". Lots of pertinent data there and on the following pages. Hope that helps! PS: Want to part with that '65 'vette of yours? Got any photos of your rides we could check out? John | | | | | Joined: Apr 2014 Posts: 62 'Bolter | | 'Bolter Joined: Apr 2014 Posts: 62 | Hot Rod John
That Vehicle Info Kit was great. I was able to document some additional items on my '61.
My 65 vette is a good driver and I'll probably hang on to it.
1961 Long Stepside Apache 10, original 235, 4 speed and 3:90 posi totally stock (owned 12 years) 1966 Chevelle (owned 53 years) | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | Glad you were able to glean some data from the GM Heritage site. Pretty awesome they provide the data at no cost now.
Is your 'vette a coupe or convertible? Love those mid year coupes! | | | | | Joined: Apr 2014 Posts: 62 'Bolter | | 'Bolter Joined: Apr 2014 Posts: 62 |
1961 Long Stepside Apache 10, original 235, 4 speed and 3:90 posi totally stock (owned 12 years) 1966 Chevelle (owned 53 years) | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 |  pictures? | | | | | Joined: Apr 2010 Posts: 436 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 436 | What can't you figure out? That is a white truck?
The four speed is an original unit. It has that so called "granny" first gear. The good old SM420. I have one in my 1962. Great transmission for a truck. | | |
