1 members (Otto Skorzeny),
85
Mod | | | Forums66 Topics128,162 Posts1,056,936 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2013 Posts: 98 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2013 Posts: 98 | I'm replacing the mastercylinder on a '52 3100 and keepin it original as it really has great brakes etc. The problem is that the original fitting on the end of the master cylinder has stripped threads and I am in need of an original stlye replacement, I have checked LMC without luck. Any suggestions where I can get an authentic piece? Thanks, oj
A shop is where you wash your hands before you pee.
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Jim Carter and Chevs of the 40s have some of those brass blocks.' | | | | | Joined: Oct 2013 Posts: 98 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2013 Posts: 98 | I went to thier website and have spoken to them, they don't have anything new but are checking the used parts shop and will call me back. Anybody else? For those interested, these master cylinders were used to lateish mid-50's. The fitting on the master cylinder accepts a banjo bolt, it is not doubleflare - this is how you get it out of the box. My original fitting replaced the provided fitting but it stripped when tightening the front brake line. I can use the provided fitting but I need the parts to make it work. It would be a banjo bolt with a distribution block for the front and rear brake lines.
| | | | | Joined: Sep 2010 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2010 Posts: 51 | Possibly take the master cylinder and fitting to a good machine shop. I would imagine they could either tap it or come up with an adapter. It may not be original, but in the 50's and 60's I am sure there were some unique repairs as well.
Love the classics! 1954 3100 1965 Mustang vert
| | | | | Joined: Jan 2011 Posts: 306 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 306 | ask brad allen if he has one
1963 c10 | | |
