6 members (Donf, FAST55, Danielbolt, cmayna, rfs56trk, Oswald), 67 guests, and 3 robots.
Topics128,154
Posts1,056,838
Members48,456
ojh
Offline
I'm replacing the mastercylinder on a '52 3100 and keepin it original as it really has great brakes etc. The problem is that the original fitting on the end of the master cylinder has stripped threads and I am in need of an original stlye replacement, I have checked LMC without luck.
Any suggestions where I can get an authentic piece?
Thanks, oj
A shop is where you wash your hands before you pee.
Jim Carter and Chevs of the 40s have some of those brass blocks.'
ojh
Offline
I went to thier website and have spoken to them, they don't have anything new but are checking the used parts shop and will call me back.
Anybody else?
For those interested, these master cylinders were used to lateish mid-50's. The fitting on the master cylinder accepts a banjo bolt, it is not doubleflare - this is how you get it out of the box. My original fitting replaced the provided fitting but it stripped when tightening the front brake line. I can use the provided fitting but I need the parts to make it work. It would be a banjo bolt with a distribution block for the front and rear brake lines.
Possibly take the master cylinder and fitting to a good machine shop. I would imagine they could either tap it or come up with an adapter. It may not be original, but in the 50's and 60's I am sure there were some unique repairs as well.
Love the classics!
1954 3100
1965 Mustang vert
ask brad allen if he has one
1963 c10
