| | | Forums66 Topics128,162 Posts1,057,047 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 12 'Bolter | | 'Bolter Joined: Aug 2011 Posts: 12 | I have a repro gas tank and repro instrument cluster in my 1952 Chevrolet 3/4 ton pickup. Whenever the truck is moving the gasoline gauge needle swings wildly as if the gasoline is sloshing around in the tank and the sending unit is following the waves up and down.
Any ideas on what the problem might be?
Hilary Smith
Hilary Smith
| | | | | Joined: Mar 2010 Posts: 10,305 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,305 | My stock needle moves in a rhythmic manner due to sloshing gas in the stock tank, and I take pleasure in it, as it means that it is reading SOME gas in the tank as opposed to being stuck at 1/2 full when I am actually running on fumes. How much is your needle moving? Carl
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | No baffles in an AD tank. The sender is a potentiometer and the wiper or coil could be corroded. I'd pull the sender and check it out with a meter. DG
Denny G Sandwich, IL
| | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Mine has gone completly crazy and depending which way you hold the gauge the needle goes everywhere. May need to find a watchmaker to do surgery but now waiting for my new gauge to show up. | | | | | Joined: Aug 2011 Posts: 12 'Bolter | | 'Bolter Joined: Aug 2011 Posts: 12 | Many thanks to all who responded -- especially Denny!
Hilary Smith
Hilary Smith
