0 members (),
254
Mod | | | Forums66 Topics128,094 Posts1,056,066 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 209 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 209 | I need to replace the shackles and bushings on my 51 3104 springs. Since I'm relatively new to buying aftermarket parts for these, is there any difference in quality between vendors i.e: any I should avoid? Thanks for any advice you may have. John | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | You can probably get those from napa.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Mar 2005 Posts: 209 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 209 | Thanks. I'll check them first. I like to deal locally whenever possible and my local NAPA is great. John | | | | | Joined: Oct 2011 Posts: 32 'Bolter | | 'Bolter Joined: Oct 2011 Posts: 32 | Any local suspension shop should be able to get them. most likely at a better price than any speciality truck vendor, plus you save on shipping & you can ask all your technical question when you pick 'em up.
| | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | Truck Shop, Brothers, LMC truck, Classic Industries, and several others have them. All this stuff is made in China but I have found the ones from the Truck Shop to be reasonably good quality. About $40 per kit. Fred
| | | | | Joined: May 2014 Posts: 3 New Guy | | New Guy Joined: May 2014 Posts: 3 | Good afternoon: I have a 1962 gmc5000 firetruck that I use at work and I need some parts to keep it going.(Actually stopping)I need to locate brake cylinder rebuild kits because mine are seeping slowly. Does anyone know where I can find them? Thanks for any help Bill
Bill Reid
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Got my shackles and stuff from Obsolete Chevy in Nashville, GA and they were made in Canada and darn good stuff! | | | | | Joined: Mar 2005 Posts: 209 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 209 | Got my shackles and stuff from Obsolete Chevy in Nashville, GA and they were made in Canada and darn good stuff! Thanks, I haven't had a chance to really do any checking yet, so I'll check them and my local NAPA. I posted this because I've learned from working on old tractors and everything in general, all parts are not created equal. Years ago. a wise friend told me "You don't need to know all the answers, just where to find them". John | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Bill Reid: ask that over on Big Bolts forum.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | |
