2 members (Nick in Manitou, walterhvogel), 73 guests, and 2 robots.
Topics128,035
Posts1,055,559
#1026982 05/07/2014 8:56 PM
Anyone know the thread and pitch of the bolts that holds the hood to the brackets?? I know they are a special bolt, I removed mine, put them in a labeled plastic bag. Only problem is the bag has run off. I have some used ones that came in the hood, but I want to run a tap in the holes and clean up the bolts until I can find my new ones. Trying to get my hood back on ??
Are these the bolts with a short shoulder the hood linkage pivots on? I seem to remember the diameter of the thread being 5/16", don't remember if the thread is coarse (18) or fine (24) threads per inch. Try one of those two taps, and if it gets tight after a turn or two, try the other one. Chasing the thread shouldn't require much more effort than a firm twist with your fingers unless they're badly rusted.
If you are talking about the shouldered pivot bolts, they are fine thread.
52Carl #1027033 05/08/2014 1:23 AM
I'll try 5/16 24.
project51, at most hardware or Harbor Freight, or Northern Tool, you can pick up one of those little plastic gizmo's that you can measure the size and pitch of a bolt.... and even screws. They are only a couple dollars and well worth the investment. I've worn out one and had to get another!
For those of you that have an Android phone, there is a free app called 'Thread Pitch' by Smart Tools.
I've found it to be very helpful and accurate, at least it is with my phone.
https://play.google.com/store/apps/details?id=kr.sira.thread&hl=en
Many other useful apps too that apply to our hobby.
https://play.google.com/store/apps/developer?id=Smart+Tools+co.&hl=en
Sir Searchalot
Sir Searchalot
Most tap and die sets come with a thread gauge and you use a caliper for Diameter. Works with "A" or "B" threads. I use HotRod's method also when I'm pretty sure of the size. Many holes on a Chevy motor and chassis are 5/16-18.
wow that will keep me from running to Lowes with nuts and bolts to get the thread and pitch !!
HHmmm neither of mine came with that ? Sears and harbor freight ?????
Both of my cheapo HF tap/die sets (10+ years old - used mostly to "chase"/clean threads) came with a screw pitch gauge.
SAE set
metro set
Their SAE/metric combo sets both come with screw pitch gauges. This style set does not come with a thread gauge.
In case anyone is interested in cheapo tools, I found the tap/die angles to be inadequate, but these tap handles work well and I'll look for this ratchet style handle on sale.
