1 members (Hotrod Lincoln),
327
Mod | | | Forums66 Topics128,169 Posts1,057,102 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2013 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2013 Posts: 35 | I have a 1965 C60 with a 292 in it. The exhaust manifold is broken and cracked and needs replaced. I'm in the process of trying to find a replacement. I have found some in various places but my problem is this....The manifold that is currently in the truck is the type where the outlet is near the rear, close to the firewall. All my sources point to the correct manifold being the one where the outlet is directly under the carb in the center of the manifold. The issue seems to be that the motor mount may not clear the center outlet manifold but it could just be the way I'm looking at it. It is swept back on the center outlet of the replacement manifold. Will this clear the motor mount? The mounts have not been modified in any way. Main reason I am asking this is also because there is a big price difference in the cost of the two manifolds and I want to make sure I order the right one. Can anyone point me in the right direction?
1965 Chevrolet C-60 292 Flatbed 2008 GMC Sierra SLE Z71 Crew Cab 1992 Chevrolet C1500 Cheyenne 5 Speed 2001 Harley Davidson FLHT Electra Glide Standard
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The ones I have worked on all have the outlet in the center. The light duty 1/2 to 1 tons have a 2 in. outlet that points rearward. The larger trucks, 50 series up have a 2 1/2 in. outlet straight down. If yours is towards the rear you will need to find one like it to match the exhaust pipe or change the exhaust pipe to match the center dump. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Nov 2013 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2013 Posts: 35 | Thanks for the info. I have found one that will work.
