2 members (Hotrod Lincoln, Shade Baby), 66 guests, and 1 robot.
Topics128,157
Posts1,056,875
Members48,458
I
I Offline
I have a 1965 C60 with a 292 in it. The exhaust manifold is broken and cracked and needs replaced. I'm in the process of trying to find a replacement. I have found some in various places but my problem is this....The manifold that is currently in the truck is the type where the outlet is near the rear, close to the firewall. All my sources point to the correct manifold being the one where the outlet is directly under the carb in the center of the manifold. The issue seems to be that the motor mount may not clear the center outlet manifold but it could just be the way I'm looking at it. It is swept back on the center outlet of the replacement manifold. Will this clear the motor mount? The mounts have not been modified in any way. Main reason I am asking this is also because there is a big price difference in the cost of the two manifolds and I want to make sure I order the right one. Can anyone point me in the right direction?
1965 Chevrolet C-60 292 Flatbed
2008 GMC Sierra SLE Z71 Crew Cab
1992 Chevrolet C1500 Cheyenne 5 Speed
2001 Harley Davidson FLHT Electra Glide Standard
Riding in the Passing Lane
The ones I have worked on all have the outlet in the center. The light duty 1/2 to 1 tons have a 2 in. outlet that points rearward. The larger trucks, 50 series up have a 2 1/2 in. outlet straight down. If yours is towards the rear you will need to find one like it to match the exhaust pipe or change the exhaust pipe to match the center dump.
1972 Chevy c10 Cheyenne Super
I
I Offline
Thanks for the info. I have found one that will work.
