2 members (Rusty Rod, LAROKE),
103
Mod | | | Forums66 Topics128,193 Posts1,057,260 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 224 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 224 | I bought a wiring harness for my '55 1st from xxxxxxx xxxxx for $150 -5% not complete just yet , waiting on switches and relays etc . V. happy with it ....My question is ( I've bought a '50 Chevy coupe ) the wiring harness for it is $643 .also plastic coated wire . Do you think I can make the $150 one work on the coupe ? same lights ,switches etc ... I know its not a Truck , also know u guys have the answers ,.
" STUCK IN THE '50'S "
| | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | I'd compare the two and see, I bet by adding a few wires it would be fine. | | | | | Joined: Jul 2013 Posts: 224 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 224 | If I buy a harness for a '55 truck then buy all switch's & relays for a '55 truck then install them in the '50 car then I think that would work . What do u think .????
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | There are a few things that will be located differently or missing from the truck to car. Wiring lengths may be different, depending on whether the wires are pre-terminated or not, I don't know what you bought. I'm sure you can make it work, but if it's built for the truck it will take some figuring. Even things like fuse box location and where the wires come through the firewall could be different, I'm guessing. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | including what #43 and 46G said, I'm thinking this: Wire length will be OK, wiring on old vehicle is pretty easy. I assume you are getting a prewired fuse box. Headlight, tail lights, dome light, license light, horn, probably relay, headlight switch, heater sw, battery stuff, starter stuff, will be similar and you will ,for sure, have to have schematics and a minor understanding of wiring. Mark the old with tags, take the old harness out in one piece or near that, design/build the new to match with improvements while following wiring diagrams. Be sure to clean all ground points down to bare metal and have many, near front lights, near rear lights, near gas sender, at dash gauges/lamps, battery to eng, eng to body, body to frame. Last two are braided strap. Truck may have ballast resistor, car may not. That's all the info you get for a car.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Instead of trying to modify a truck harness, I would use a Hotrod Wires 12 circuit. You can custom route the wires wherever they need to be. I used one of these on my '56 and liked it so well I bought another one for my project truck. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Wanderer: This is a good post for you to report what you did, what you spent and how it turned out. It may be weeks or longer before you know, but please come back and report with details.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jul 2013 Posts: 224 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 224 | I will report back when finished , now I'm leaning to the $150 one , I'm installing 1 in my '55 1st now , that'll take a couple weeks . ( I work slow but steady ) It's going great & I have a print that I got off this forum wire numbers and colors are the same , looking at the '50 coupe all switches ,relays lights are located in same places . I can only locate 2 fuses for brake & tail lights (I'm using inline fuses)the other items I think are on a circuit breaker off light switch. I pulled off the truck to do some work on the coupe . picked up a '57 rear end , drive shaft a 250 with a 350 auto so it will be several weeks before I get to wiring on the coupe ,when I do I'll put the results on this forum...
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | We are amped up and electrified to rectify any feedback or buzz on this and I will be fused to my computer.
