4 members (MickeyP, Phak1, carbking, 1 invisible),
129
0
Mod | | | Forums66 Topics128,260 Posts1,058,322 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 127 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 127 | Hi All Is there a way to replace just the socket fitting from the top of the upper shock mounts? Can you get replacement fittings and press or weld them in?
The mounts themselves are solid and it seems like a shame to replace the whole thing.
52 3100 project 54 3100 / 3112 ice cream truck, next project
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I've seen universal shock mount bushings kits at the auto parts store
They come with rubber bushings and 2 cup washers.
| | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | Wurlitzer:
Is the hole in the mount worn larger than normal due to failed bushings. If so, I suppose you could weld the hole closed and then drill the proper hole size for the shock shaft. But, in the end all this would be easiest if you remove the entire mount to either replace or weld.
Good luck. | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | I think Classic Truck Parts (Chevy Duty) has the upper shock brackets available. You'd have to grind the rivets off and remove the old bracket and bolt or rivet a new one on.... John | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | I think that wurlizter46 is interested in just replacing the "cup/socket/fitting" that the shock's top-post goes through in upper mounting plate. | | | | | Joined: Oct 2009 Posts: 127 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 127 | Yes, is there some way to replace just that pressed-on cup/socket/fitting thing? Some of mine are missing or loose. The brackets are otherwise solid, with a clean hole where the cup thingee should be. It seems that a replacement would have to be welded or pressed on, or threaded together from both sides of the hole, since the shock pushes and pulls in both directions? I think that wurlizter46 is interested in just replacing the "cup/socket/fitting" that the shock's top-post goes through in upper mounting plate.
