| | | Forums66 Topics128,036 Posts1,055,458 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 289 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 289 | I have a small project I want to spray with Rustoleum gloss black. Wondering if mineral spirits or acetone would be better to thin it with and how much? So far I've seen 10%, 25% and 40%. I have also seen that adding a hardner may help. I know many of you have painted your frames with it, so thought I'd see what tips I can get. | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | as for which thinner to use, Acetone will evaporate faster thinner takes longer so they affect how fast or slow. Mix them if you want. How much has more to do with the size nozzle your gun has. Thicker for larger and thinner for smaller till you get the pattern you're looking for.
I use up old hardener in Rustoleum whenever I shoot it. About a cap full per qt of paint, then I reduce.
| | | | | Joined: Oct 2013 Posts: 97 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 97 | hey 57, I am thinking Rustoleum recommends acetone as I recently talked to their customer service people about cleaning or reducing their automotive line of paints ..... they recommended not to reduce it and if I had to, use acetone .... they make so many kinds of paint though I could be wrong .... their technical people were knowledgeable and helpful .... let us know what you use so we can know whether or not it worked well lane
sweetpealane
| | | | | Joined: Jan 2013 Posts: 2,232 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,232 | 57, i painted my frame with a paint brush. there are no paint brush strokes since it all levels out and looks better then i thought it would.
Chris | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | Standard Rustoleum in the quart cans calls for thinning up to 15% with acetone. I have done it many times and it works/sprays (1.3 tip in HVLP gun) fine. The dry time is extended after thinning. | | | | | Joined: Oct 2006 Posts: 289 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 289 | My project came out real nice. It's a fiberglass trailer to tow behind my Harley. Originally tried rustoleum rattle cans, but had runs and spotty coverage.
So sanded, scuffed and washed it real good. Ended up borrowing paint, clear and hardner from a friend that he said was enamel and shot it yesterday with a HF HVLP gun. He suggested 4:1 on the hardener and I guess he was close enough.
While it has some orange peel, the little woman loves it and that's what counts. Maybe I'll link to some to pics later on. | | |
