Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
0 members (), 172 guests, and 1 robot.
Topics128,274
Posts1,058,433
Members48,490
#1025033 04/29/2014 3:37 PM
I have a small project I want to spray with Rustoleum gloss black. Wondering if mineral spirits or acetone would be better to thin it with and how much? So far I've seen 10%, 25% and 40%. I have also seen that adding a hardner may help. I know many of you have painted your frames with it, so thought I'd see what tips I can get.
Eric
http://s1199.photobucket.com/user/sparky234/library/My%2057%20Chevy%20Stepside?sort=3&page=1
'57 Chevy 3100 (Little Red)
'81 RD350 LC - Fun, Fun, Fun
'83 GS1100E - Pocket Rocket
as for which thinner to use, Acetone will evaporate faster thinner takes longer so they affect how fast or slow. Mix them if you want.
How much has more to do with the size nozzle your gun has. Thicker for larger and thinner for smaller till you get the pattern you're looking for.
I use up old hardener in Rustoleum whenever I shoot it. About a cap full per qt of paint, then I reduce.
Give me ambiguity
or give me something else
CASO #1025154 04/29/2014 10:42 PM
hey 57,
I am thinking Rustoleum recommends acetone as I recently talked to their customer service people about cleaning or reducing their automotive line of paints ..... they recommended not to reduce it and if I had to, use acetone .... they make so many kinds of paint though I could be wrong .... their technical people were knowledgeable and helpful .... let us know what you use so we can know whether or not it worked well
lane
sweetpealane
57, i painted my frame with a paint brush. there are no paint brush strokes since it all levels out and looks better then i thought it would.
Chris
Standard Rustoleum in the quart cans calls for thinning up to 15% with acetone. I have done it many times and it works/sprays (1.3 tip in HVLP gun) fine. The dry time is extended after thinning.
My project came out real nice. It's a fiberglass trailer to tow behind my Harley. Originally tried rustoleum rattle cans, but had runs and spotty coverage.
So sanded, scuffed and washed it real good. Ended up borrowing paint, clear and hardner from a friend that he said was enamel and shot it yesterday with a HF HVLP gun. He suggested 4:1 on the hardener and I guess he was close enough.
While it has some orange peel, the little woman loves it and that's what counts. Maybe I'll link to some to pics later on.
Eric
