3 members (TUTS 59, papas52, 1 invisible),
151
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,157 Posts1,056,887 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2013 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2013 Posts: 35 | I am overhauling the brake system on my 65 C60 and I have a question about the rear wheel cylinders. My system has a line that comes in to the bottom cylinder, then a line that branches out of the front of the bottom cylinder and up to the upper cylinder. This cylinder is equipped with a bleeder screw on the back side. The upper cylinder does not have a spot for a line to thread into the back. It is just solid. I found wheel cylinder info on raybestos.com. It seems the only cylinder available is the lower one that has the threaded line holes on both sides. Would I just put a threaded plug into one of these and use it for the upper or what? They current cylinders are in real good shape but I'm having a hard time find replacement pistons for the upper as they are sort of pitted. Are these pistons available? Rebuild kits don't come with them. The bore is 1 1/2.
1965 Chevrolet C-60 292 Flatbed 2008 GMC Sierra SLE Z71 Crew Cab 1992 Chevrolet C1500 Cheyenne 5 Speed 2001 Harley Davidson FLHT Electra Glide Standard
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy IHBoilermaker, could you tell us the part number of the Raybestos wheel cylinders you're inquiring about? | | | | | Joined: Nov 2013 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2013 Posts: 35 | WC37042 is the Raybestos number, 3/8 threads for brake line.
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy IHBoilermaker, it looks like the crossover line goes up from the bottom wheel cylinder to the top cylinder inside the brake drum leaving only the bleed screw on the outside of the backing plate at the top. Both wheel cylinders are available at RockAuto, Raybestos p/n WC37042 $20.79, and p/n WC18196 $27.79, hope that helps. | | | | | Joined: Nov 2013 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2013 Posts: 35 | Ok this is kind of what I figured. The thing that was throwing me of was that one cylinder was 3/8 inlet and the other was 7/16 inlet but upon further research I see that these will in fact get the job done. Thanks for your help.
| | | | | Joined: Jul 2014 Posts: 4 New Guy | | New Guy Joined: Jul 2014 Posts: 4 | Thanks again 3B I just order all 4 rear wheel cylinders for my Viking from Rock auto . and on a side note I just received my rear hardware kit you recomended (raybestos H9223) it was spot on got it on Feebay for $12....... . . will let you know how the wheel cylinders thanks ...Sp . . . . .
| | | | | Joined: Jun 2016 Posts: 2 Moderated | | Moderated Joined: Jun 2016 Posts: 2 | Hi new to posting have a 66 LCF with brake problems. I see a lot of folks recommending Rock auto. when I go on there site is doesn't allow me to search for c60 parts. What am I doing wrong Phil | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy pkd66, welcome, I have many catalogues and parts books so I can search by part number, most sites do not have the ability to search for truck parts heavier than one ton. If you will tell us what in particular you are looking for we may be able to help you. | | |
