0 members (), 152 guests, and 2 robots.
Topics128,127
Posts1,056,680
Members48,452
I
I Offline
I am overhauling the brake system on my 65 C60 and I have a question about the rear wheel cylinders. My system has a line that comes in to the bottom cylinder, then a line that branches out of the front of the bottom cylinder and up to the upper cylinder. This cylinder is equipped with a bleeder screw on the back side. The upper cylinder does not have a spot for a line to thread into the back. It is just solid. I found wheel cylinder info on raybestos.com. It seems the only cylinder available is the lower one that has the threaded line holes on both sides. Would I just put a threaded plug into one of these and use it for the upper or what? They current cylinders are in real good shape but I'm having a hard time find replacement pistons for the upper as they are sort of pitted. Are these pistons available? Rebuild kits don't come with them. The bore is 1 1/2.
1965 Chevrolet C-60 292 Flatbed
2008 GMC Sierra SLE Z71 Crew Cab
1992 Chevrolet C1500 Cheyenne 5 Speed
2001 Harley Davidson FLHT Electra Glide Standard
3B Offline
Hy IHBoilermaker, could you tell us the part number of the Raybestos wheel cylinders you're inquiring about?
I
I Offline
WC37042 is the Raybestos number, 3/8 threads for brake line.
3B Offline
Hy IHBoilermaker, it looks like the crossover line goes up from the bottom wheel cylinder to the top cylinder inside the brake drum leaving only the bleed screw on the outside of the backing plate at the top. Both wheel cylinders are available at RockAuto, Raybestos p/n WC37042 $20.79, and p/n WC18196 $27.79, hope that helps.
I
I Offline
Ok this is kind of what I figured. The thing that was throwing me of was that one cylinder was 3/8 inlet and the other was 7/16 inlet but upon further research I see that these will in fact get the job done. Thanks for your help.
Thanks again 3B I just order all 4 rear wheel cylinders for my Viking from Rock auto
and on a side note I just received my rear hardware kit you recomended
(raybestos H9223) it was spot on
got it on Feebay for $12.......
will let you know how the wheel cylinders thanks ...Sp
Moderated
Moderated
Hi new to posting have a 66 LCF with brake problems. I see a lot of folks recommending Rock auto. when I go on there site is doesn't allow me to search for c60 parts. What am I doing wrong
Phil
3B Offline
Hy pkd66, welcome, I have many catalogues and parts books so I can search by part number, most sites do not have the ability to search for truck parts heavier than one ton. If you will tell us what in particular you are looking for we may be able to help you.
