Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Hotrod Lincoln, UtahYork, 66flea), 163 guests, and 3 robots.
Topics128,284
Posts1,058,523
Members48,490
I recently purchased a 1951 3/4 ton Chevy pick up truck. Title and odometer show 36,000 original miles and the body and frame just make you say how could this be so clean original paint that is patina but the frame,body, running boards, floor boards look like they are 10 years old not 60 and original split rims have almost no rust...somehow she must have lead a very sheltered life, claim was all owners stored her inside???. I was sold her to be almost all original...we have all hear that ??but she sure looks correct ?? here are some numbers I pulled from the vin tag, engine block and head...I thought these would be a good place to start and maybe you experts can tell me what I have or don't have. Looking to restore her but need to know what I have.
VIN tag = 14JRE3802
14 =Baltimore MD
J =1951
R 3600
E=May
3802 =2802 unit built in 1951
Hopefully I have this right??
Engine Block
Casting code 3835497 =216 CI I think correct for 1951??/
Engine serial number AJCM290639 looks again correct??
Block Date Casting Code: I believe this is hidden behind the starter need to remove to read??
Does the block look correct for 1951 3/4 ton???
Head
Casting Code 3835517
Under the valve cover Date casting Code E41 = May 4th 1951 seems correct for a May build on the Vin tag? Also marked under the valve cover is the CON12 marking
These numbers also look correct to me BUT the numbers are all inside the valve cover in some cases I see the casting code outside the valve cover on the outside of the head but all three numbers on mine are under the valve cover?Is this an issue? or am I ok with all 3 correct numbers cast inside the valve cover?
I have a 1958 corvette all original all matching so following these numbers was slightly familiar but all these animals are different and the truck guys like you all know the ins and outs I'm all ears????
Please tell me what you think when I buy older vehicles and am promised numbers matching I always go in very hesitant...at my rookie glance these number seem to follow the carts...experts what do you think do they look good??? what's suspect???
All help from everyone is greatly appreciated only way to learn is ask the guys who really know this stuff!
In your opinion is this the correct original block and head???
Gas Pumper
Gas Pumper
There is no such thing as numbers matching for this vintage. There are just telltale signs that can help you. For example, does the radiator (on the top tank towards engine) have a 51 stamped on it? You have the engine codes and all seems to be in order there.
Not a lot of people put ANOTHER 216 engine in their 1951. Usually what happens is, the 216 goes bad, its after 1953 so a new style 235 is installed in its place. So, if you have a 216 engine (2 acorn nuts on the valve cover) and a torque tube rear end (enclosed driveline), chances are you have a very well kept original truck.
I have a 1950 4400 that has been sitting in a barn all its life. The metal is like brand new with very little flash rust. Runs and drives great. Its amazing how a nice parking place INDOORS will change history!
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
I really appreciate the response there are some little things I will check out in the morning 51 on radiator and 2 acorn nuts on valve cover...
not exactly sure what you meant by: a torque tube rear end (enclosed driveline) I'd rather look dumb ask and learn.....all ears here!!
Gas Pumper
Gas Pumper
There is no driveshaft like in newer cars. Its enclosed inside a tube. The rear end is one piece all the way to the transmission. Lots of people like to change that, so if yours is truly original, that's the way it should look.
Deve
The Think Tank
The closed system is the torque tube design on your truck, the open system is as your modern day cars with the drive shaft/universal exposed or open. I believe they started the open style on the taskforce trucks. 1955 1st series or the 6 volt ones and earlier at least on the trucks were closed or torque tube style. Someone correct me if I am wrong.
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my sweet ride." -Amen
56 Chevy 3100
50's Chevy Cltr,
All your numbers nicely "match".
Congratulations, especially if you are interested in staying as "original" as possible (original parts and/or original-style/design/appearance parts).
You may want to obtain this Shop Manual in hardcopy or on CD. A 1951 Truck Owner's Manual is also available.
Shop Manual on-line and Owner's Manual on-line
Thanks for all the help...really really appreciate the advice and what to look at and what to look for!!if its very correct then ill of course strive to keep her that way! That's the look I like anyway. Currently trying to find someone to work with me on the original split rims, tires are very dry ROT...most people over the phone will not even consider changing tires for me? They have almost no signs of rust. Would like to mount new tires on the original rims just need to find someone who will work with me.
..."maybe" a big truck shop would do it ???
I will comment on the torque tube. If it is a 3/4 Ton then the rear portion of the driveshaft is open.
1951 1 Ton Completed
We have gone over and over the truck the only item that looks NON original seems to be the torque tube. Down to ID tags on starter & generator... my drive shaft is NOT covered with the torque tub...Not sure if this means it was totally changed over to a common drive shaft or if it is simply missing the TUBE?? I am no expert on this and my ready says that many people removed the torque tub...It sounds like there are speed advantages to removing it along with ease of getting to the "Guts" of the drive shaft....Trying to decide if I should transition back to original part of the torque tube or not?? I realize its not original what are the mechanical advantages of the drive shaft vs the torque tube on this 3600 truck? All info and advice appreciated
the 3600 3/4T truck didn't have a full length torque tube, you might find the manuals here helpful in determining driveline 'originality' .... eliminating a torque tube isn't the "speed advantage", changing the rear end gearing or changing to a different open drive rear end with better gearing affects speed
