| | | Forums66 Topics128,075 Posts1,056,007 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 50 | Put a sbc gm crate 350'in my 52' and blew a headgasket. I've replaced the head gaskets trucks running fine but now after all winter with the heads off I'm trying to flush out the black milkshake and rust from the blown head gasket. Tried dawn dish washing liquid and greased lightning an still got light tea colored water. I read white vinegar flush any other ideas. Thanx | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | I've had good luck with off the shelf cooling system flush. Water and a couple cans of flush, run it till hot and drain. Best to pull bottom hose for a fast drain. | | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | 4 ounces of muriatic acid, fill with water, run the engine to operating temperature, drain, neutralize with water and a box of baking soda for 5 minutes. Drain, flush with water twice, then refill with 50/50 antifreeze and water. Jerry
| | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | Back when Dex-Cool first came out and everyone was mixing them, it made a sludgey mess in the cooling system. We would flush with laundry detergent. Tide, Wisk, doesn't matter what brand. It did a wonderful job cleaning things out.
Of course you will then need to flush with straight water a couple times. | | | | | Joined: Apr 2013 Posts: 165 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 165 | The oil cooler on my diesel p/u gave out and the higher pressure of the oil pump pumped oil into the cooling system. It was a real mess. I tried dishwasher detergent, dish soap, and purple power. Nada other than it smelt good. Then I tried the stuff called Simple Green. Worked great. You will still have to do it several times but it will work.
Rust should be handled as Hotrod mentioned.
Good Luck
36 Chevy 1.5 ton - rusting away 52 Chevy 3100 - in progress 72 Chevy K20 - DD
PANTS UP DON'T LOOT! PANTS UP DON'T LOOT!
NEVER watch another man eat a banana.
| | | | | Joined: Aug 2013 Posts: 568 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 568 | Try tide laundry detergent. The powdered form.
