0 members (), 38 guests, and 4 robots.
Topics128,089
Posts1,056,004
Members48,430
#1023594 04/22/2014 11:17 PM
Put a sbc gm crate 350'in my 52' and blew a headgasket. I've replaced the head gaskets trucks running fine but now after all winter with the heads off I'm trying to flush out the black milkshake and rust from the blown head gasket. Tried dawn dish washing liquid and greased lightning an still got light tea colored water. I read white vinegar flush any other ideas. Thanx
I've had good luck with off the shelf cooling system flush.
Water and a couple cans of flush, run it till hot and drain. Best to pull bottom hose for a fast drain.
H Online: Content
4 ounces of muriatic acid, fill with water, run the engine to operating temperature, drain, neutralize with water and a box of baking soda for 5 minutes. Drain, flush with water twice, then refill with 50/50 antifreeze and water.
Back when Dex-Cool first came out and everyone was mixing them, it made a sludgey mess in the cooling system. We would flush with laundry detergent. Tide, Wisk, doesn't matter what brand. It did a wonderful job cleaning things out.
Of course you will then need to flush with straight water a couple times.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
The oil cooler on my diesel p/u gave out and the higher pressure of the oil pump pumped oil into the cooling system. It was a real mess. I tried dishwasher detergent, dish soap, and purple power. Nada other than it smelt good. Then I tried the stuff called Simple Green. Worked great. You will still have to do it several times but it will work.
Rust should be handled as Hotrod mentioned.
Good Luck
36 Chevy 1.5 ton - rusting away
52 Chevy 3100 - in progress
72 Chevy K20 - DD
PANTS UP DON'T LOOT! PANTS UP DON'T LOOT!
NEVER watch another man eat a banana.
Try tide laundry detergent. The powdered form.
