0 members (), 196 guests, and 1 robot.
Topics128,081
Posts1,056,078
Members48,434
#1021544 04/14/2014 2:14 AM
I'm working on a 53 3/4 ton that's been converted to 12 volts.
the motor was in the truck when I got it and is 12 volts.
the colors of the wires are red which is the hot.
white, yellow, and green.
the switch has 4 terminals B P H and L.
I figure these to be batt, park, high and low
I don't know which of the yellow, green, and white wires are which.
I guessing the ground is through the mounting to the cab.
any ideas out there?
thanks
rolf
1963 c10
I have a new port wiper and switch with similar labels
Although I have a blue wire not green
Try
L-yellow
H-white
B-red
P-green
A meter set on continuity might help
Sir Searchalot
Sir Searchalot
Have a fuse inline when experimenting.
rgie #1021808 04/15/2014 12:36 PM
bart,
I do have a fuse in the circuit I'm using a 10 amp.
dad,
that wire set up blew the fuse.
I do have a multi meter around here some where.
back to the drawing board.
thanks
rolf
1963 c10
Check the motor for any Markings
If there is a company label maybe you can call?
I don't know if your is a Newport or not.
Some of the vendors sell a overseas model.
Here a pic of the back of my Switch
Was this working before?
dad
that is exactly what my switch looks like.
i'll see what I can see on the motor.
yes I had it running before I put it in.
rolf
1963 c10
dad it has a sticker on it that looks like it says new port engineering.
1963 c10
Try giving them a call
https://www.newportwipers.com/
They had been very helpful to me in the past
Sir Searchalot
Sir Searchalot
1. Did the motor have wires on it not connected to switch or did switch have wires on it not connected to motor?
2. Is motor on bench or installed?
3. Get diagram of motor hookup on web or Co. as suggested
4. I would test switch function separately and make a list of what terms make contact to each other at what position.
5. I would test motor separately on bench with voltage/fuse to determine HI, Lo, off/park wires.
6. I guess it's not the type of motor with cable control, I guess it is not set up for washer.
7. The web shows as Dads has said, looking at back of switch..clockwise..red yel wht blu. You say green because you may be color blind smile. There seems to be a black wire coming off of motor to attach to good chassis ground, or at least a terminal for a black wire. I think I see that wire in Dads pic?
I called newport.
they confirmed dads wire-up and said the park wire may be blue or green. i reconfirmed the wire-up and i added a ground wire from the motor.
newports tech guy thinks the motor is bad or bound.
before i take it out and test it i think i'll get a new switch.
the motor only has the red green yellow and white wires. the motor is in the truck. there is no cable control or washer on the motor.
i'll keep everyone posted
thanks
rolf
1963 c10
Sir Searchalot
Sir Searchalot
You can test if it is the switch by just touching the appropriate wires together after taking them off switch. If it still blows the fuse, it's not the switch. You can also test the switch with continuity test on it's terminals. That's what Dads was saying. Unless you just want to buy a switch smile
