8 members (PAUL Berardi, Phak1, DaveV, Cheapskate1229, Otto Skorzeny, carbking, Peggy M, Wayne67vert),
138
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,111 Posts1,056,244 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 306 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 306 | I'm working on a 53 3/4 ton that's been converted to 12 volts.
the motor was in the truck when I got it and is 12 volts.
the colors of the wires are red which is the hot. white, yellow, and green.
the switch has 4 terminals B P H and L.
I figure these to be batt, park, high and low
I don't know which of the yellow, green, and white wires are which.
I guessing the ground is through the mounting to the cab.
any ideas out there?
thanks rolf
1963 c10 | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I have a new port wiper and switch with similar labels Although I have a blue wire not green
Try
L-yellow H-white B-red P-green
A meter set on continuity might help | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Have a fuse inline when experimenting.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jan 2011 Posts: 306 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 306 | bart, I do have a fuse in the circuit I'm using a 10 amp.
dad, that wire set up blew the fuse. I do have a multi meter around here some where.
back to the drawing board.
thanks rolf
1963 c10 | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Check the motor for any Markings If there is a company label maybe you can call? I don't know if your is a Newport or not. Some of the vendors sell a overseas model. Here a pic of the back of my Switch Was this working before? | | | | | Joined: Jan 2011 Posts: 306 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 306 | dad that is exactly what my switch looks like. i'll see what I can see on the motor. yes I had it running before I put it in.
rolf
1963 c10 | | | | | Joined: Jan 2011 Posts: 306 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 306 | dad it has a sticker on it that looks like it says new port engineering.
1963 c10 | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Try giving them a call https://www.newportwipers.com/They had been very helpful to me in the past | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | 1. Did the motor have wires on it not connected to switch or did switch have wires on it not connected to motor? 2. Is motor on bench or installed? 3. Get diagram of motor hookup on web or Co. as suggested 4. I would test switch function separately and make a list of what terms make contact to each other at what position. 5. I would test motor separately on bench with voltage/fuse to determine HI, Lo, off/park wires. 6. I guess it's not the type of motor with cable control, I guess it is not set up for washer. 7. The web shows as Dads has said, looking at back of switch..clockwise..red yel wht blu. You say green because you may be color blind  . There seems to be a black wire coming off of motor to attach to good chassis ground, or at least a terminal for a black wire. I think I see that wire in Dads pic?
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jan 2011 Posts: 306 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 306 | I called newport. they confirmed dads wire-up and said the park wire may be blue or green. i reconfirmed the wire-up and i added a ground wire from the motor.
newports tech guy thinks the motor is bad or bound.
before i take it out and test it i think i'll get a new switch.
the motor only has the red green yellow and white wires. the motor is in the truck. there is no cable control or washer on the motor.
i'll keep everyone posted
thanks
rolf
1963 c10 | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | You can test if it is the switch by just touching the appropriate wires together after taking them off switch. If it still blows the fuse, it's not the switch. You can also test the switch with continuity test on it's terminals. That's what Dads was saying. Unless you just want to buy a switch
