| | | Forums66 Topics128,050 Posts1,055,670 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2014 Posts: 86 Shop Shark | | Shop Shark Joined: Jan 2014 Posts: 86 | Have a 59 Apache with a 6 cylinder. Amp meter jumps around, particulary at idle. When headlights turned on, amp needle rock solid. Pretty steady at driving speed when lights off. Battery stays charged.
Is this something I can adjust to fix, or am I better off leaving well enough alone?
Thanks! Bob
1959 Chevy Apache Short Bed Step Side 1967 Cadillac DeVille Convertible 1967 Pontiac Firebird Convertible
| | | | | Joined: Feb 2004 Posts: 29,769 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,769 | It sounds like the closing voltage of the cutout relay might be off a little. That's not a difficult fix, but you need to find someone familiar with adjusting a 3-unit regulator. One simple fix is to raise the idle speed a little, maybe 50-100 RPM faster. Good luck! Jerry
