2 members (BC59, Uncles51), 103 guests, and 1 robot.
Topics128,041
Posts1,055,481
Members48,424
#1021567 04/14/2014 3:36 AM
Have a 59 Apache with a 6 cylinder. Amp meter jumps around, particulary at idle. When headlights turned on, amp needle rock solid. Pretty steady at driving speed when lights off. Battery stays charged.
Is this something I can adjust to fix, or am I better off leaving well enough alone?
Thanks! Bob
1959 Chevy Apache Short Bed Step Side
1967 Cadillac DeVille Convertible
1967 Pontiac Firebird Convertible
H Online: Content
It sounds like the closing voltage of the cutout relay might be off a little. That's not a difficult fix, but you need to find someone familiar with adjusting a 3-unit regulator. One simple fix is to raise the idle speed a little, maybe 50-100 RPM faster. Good luck!
