3 members (Napco Man, baldeagle, jmoore), 160 guests, and 0 robots.
Topics128,037
Posts1,055,469
Members48,424
#1021567 04/14/2014 3:36 AM
Have a 59 Apache with a 6 cylinder. Amp meter jumps around, particulary at idle. When headlights turned on, amp needle rock solid. Pretty steady at driving speed when lights off. Battery stays charged.
Is this something I can adjust to fix, or am I better off leaving well enough alone?
Thanks! Bob
1959 Chevy Apache Short Bed Step Side
1967 Cadillac DeVille Convertible
1967 Pontiac Firebird Convertible
It sounds like the closing voltage of the cutout relay might be off a little. That's not a difficult fix, but you need to find someone familiar with adjusting a 3-unit regulator. One simple fix is to raise the idle speed a little, maybe 50-100 RPM faster. Good luck!
