5 members (bnauman, Oswald, 3B, dt235sd, Bill Hanlon), 84 guests, and 3 robots.
Topics128,175
Posts1,057,115
Members48,463
I have a new spectra tank in my 51. Gotten to the point of reconnecting it to the original filler neck. Simple task, right?
I actually anticipated some difficulty with this knowing how clumsily it came apart. So I intentionally left the tank un-strapped to give some freedom to adjust.
There doesn't seem to be a sweet spot at which the angle of the filler neck matches up with the tubes on the tank. Doesn't match worth a crap actually. Bought new filler and vent hoses from Carter. I can get it connected to both sides, but it looks goofy and not enough material on one side or the other to feel good about tightening the hose clamp.
I'm thinking I need to go to the FLAPS and just get a couple hoses about an inch longer and be done with it. But before I give in and do that...just wanted to check and see if anyone else had a similar problem, or if there's some little trick I'm missing.
1951 3100
New tanks don't line up well. I re-tweeked my filler neck to make it work.
Bruce
My Trucks
Stuff I Collect
Riding in the Passing Lane
Be sure to get fuel filler hose. Radiator hose may come apart with gasoline.
1972 Chevy c10 Cheyenne Super
Here's a spectra tank and original filler
Fit is not that bad
Try your other filler neck.
NAPA is your friend for filler hose connections. Some you have to buy a short stick, about 15 bucks, and some may sell it by the inch??....My napa use to but not anymore.
Are you sure you have a genuine Spectra tank?
This is the Spectra tank line up in a '50:
http://www.pbase.com/dennygraham/image/119916599
This is the Off Shore tank line up from JC in the same truck:
http://www.pbase.com/dennygraham/image/120036975
DG
Denny G
Sandwich, IL
My Spectra tank/filler neck fit perfectly. Zero issues with the Spectra tank fit. 1952 1/2 ton.
DG
LOL. Goodness sakes!
Yes, it's a spectra. Bought from rock auto. The fit is just off a little, not 180 degrees like that one. It can be overcome with a slightly longer hose, and may not even need that if I fiddle with it long enough. I just need another 1/2 to 3/4 inch of hose on the steel.
Similar to DADS example. Looks like his alignment was OK but not perfect like yours.
1951 3100
Installed mine this week , had no problems .
" STUCK IN THE '50'S "
