1 members (1 invisible),
368
Mod | | | Forums66 Topics128,162 Posts1,057,043 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 863 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 863 | Bought the stainless steel tail lamp conduit for my '49 Chevrolet 3100 1/2 ton. How do these %&#@ things install? Think I got the tail lamp end figured out but how about the frame end. Anyone got photos how they installed them would be a GREAT help!
1949 Chevrolet 3100 Series 1/2 ton Pickup 1964 Chevrolet C10 (Ol' Yella) (SOLD) 1958 Chevrolet Biscayne 2 door (SOLD) 1970 VW Beetle
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I installed mine in the trash can.
And I purchased some asphalt loom.
| | | | | Joined: Jul 2013 Posts: 863 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 863 | So how many like me got suckered into buying the stainless steel conduit and they ended up in the trash?
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I'm sure there's a way to make it work and look good.
Maybe someone will post a pic. Don't toss it yet. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Found a reference pic from a car show, the hot rod guys like to use those things, looks like he found some kind rubber grommet for the rear? ...pic... | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | That looks really nice! Before you toss it in the can, send it to me!
Perhaps if you showed us the parts that are included? I am interested in this solution because my entire build is centered around stainless. Where did you get it?
| | | | | Joined: Jul 2013 Posts: 863 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 863 | I figured it out today. You have to slightly bend the cone shaped end and feed it through the tail lamp bracket. Then squeeze the cone at 90 degrees and round it back out. The cone will lock in behind the tail lamp when you tighten the tail lamp to the bracket. The sliding sleeve will need an "o" ring and 3M emblem adhesive. Slide the sleeve over the cone with the "o" ring inserted in the sleeve. Line the sleeve with emblem adhesive and it is installed! Deve, I got these on E-Bay. They come in 12" and 19" lengths. Get the 19" length. The 12"'s are too short.
| | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | As info. You can get these at Jim Carter. $4.25 ea. Stainless Loom Harold
Harold Is a restoration ever finished? | | | | | Joined: Dec 2008 Posts: 95 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 95 | A part from a kit that you paid for to fix and or make useable from another kit that you need to buy to make the first part work to get that? | | | | | Joined: Oct 2012 Posts: 58 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2012 Posts: 58 | A part from a kit that you paid for to fix and or make useable from another kit that you need to buy to make the first part work to get that? Huh? | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Bought the stainless steel tail lamp conduit for my '49 Chevrolet 3100 1/2 ton. How do these %&#@ things install? Think I got the tail lamp end figured out but how about the frame end. Anyone got photos how they installed them would be a GREAT help! I have written a "How TO"  on this subject - Tail Light Bracket Modification to use Stainless Conduit. I have submitted this for the Tech. Tips. Just waiting for it to be published. If you would like an advance copy send me your Email. Harold
Harold Is a restoration ever finished? | | | | | Joined: Nov 2006 Posts: 324 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 324 | I'm thinking of sliding a piece of shrink tube over the conduit up to the light, once in place the heat gun can shrink the tube snug and make it waterproof. Just thinking about it, going to try this soon. | | | | | Joined: Apr 2004 Posts: 5,091 Authorized Pest | | Authorized Pest Joined: Apr 2004 Posts: 5,091 | Harold was going to post this but he may still be working or something important like that. The Tech Tip is finally done. Got some great LARGE pictures for seeing detail. If you have questions or additional input, be sure to post here. If Harold needs to expand the tip, or add stuff, he'll pull it from here. Thanks for doing this Harold. Sorry (as always) for the delay. Peggy
~ Peggy M 1949 Chevrolet 3804"Charlie" - The Stovebolt FlagshipIn the Gallery"Success comes in 'cans' ..." | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Peggy, Thank you  for the work you do in keeping the forum going forward. Harold
Harold Is a restoration ever finished? | | | | | Joined: Apr 2004 Posts: 5,091 Authorized Pest | | Authorized Pest Joined: Apr 2004 Posts: 5,091 | Harold,
You are most welcome. It is a lot of fun. I wish I had more time and more knowledge. But ... we keep moving ahead, so that's good.
Thanks for taking the time to write this up. I have a few more in the TT pile I'd like to get done before the month is out!
Peg
~ Peggy M 1949 Chevrolet 3804"Charlie" - The Stovebolt FlagshipIn the Gallery"Success comes in 'cans' ..." | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Thank you, Harold. Very nice. Thank you, Peg
