2 members (Ole49GMC, Hush),
74
Mod | | | Forums66 Topics128,169 Posts1,057,102 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2014 Posts: 3,690 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,690 | I have a new spectra tank in my 51. Gotten to the point of reconnecting it to the original filler neck. Simple task, right?
I actually anticipated some difficulty with this knowing how clumsily it came apart. So I intentionally left the tank un-strapped to give some freedom to adjust.
There doesn't seem to be a sweet spot at which the angle of the filler neck matches up with the tubes on the tank. Doesn't match worth a crap actually. Bought new filler and vent hoses from Carter. I can get it connected to both sides, but it looks goofy and not enough material on one side or the other to feel good about tightening the hose clamp.
I'm thinking I need to go to the FLAPS and just get a couple hoses about an inch longer and be done with it. But before I give in and do that...just wanted to check and see if anyone else had a similar problem, or if there's some little trick I'm missing.
1951 3100
| | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | New tanks don't line up well. I re-tweeked my filler neck to make it work.
Bruce | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Be sure to get fuel filler hose. Radiator hose may come apart with gasoline. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | NAPA is your friend for filler hose connections. Some you have to buy a short stick, about 15 bucks, and some may sell it by the inch??....My napa use to but not anymore. | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | My Spectra tank/filler neck fit perfectly. Zero issues with the Spectra tank fit. 1952 1/2 ton. | | | | | Joined: Jan 2014 Posts: 3,690 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,690 | LOL. Goodness sakes! Yes, it's a spectra. Bought from rock auto. The fit is just off a little, not 180 degrees like that one. It can be overcome with a slightly longer hose, and may not even need that if I fiddle with it long enough. I just need another 1/2 to 3/4 inch of hose on the steel. Similar to DADS example. Looks like his alignment was OK but not perfect like yours.
1951 3100
| | | | | Joined: Jul 2013 Posts: 224 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 224 | Installed mine this week , had no problems .
" STUCK IN THE '50'S "
