7 members (55shaker, Nick in Manitou, Leo, 54farmtruck, Hotrod Lincoln, Bill Hanlon, 1 invisible), 108 guests, and 1 robot.
Topics128,211
Posts1,057,468
Members48,471
I have a 48 3100 235 wt a 3 speed, I am going to a 1956 235 and 3 speed out of a belair. The 3 speed I have now is a torque tube set up and i am being told that the 235 wt 3 spd I am getting is not set up for a torque tube. Is there a conversion out there or an adaptor so I can use the set up I currently have with the new trans or do I swap trans. Thank you in advance
Adam
ODSS Lawman
ODSS Lawman
The easiest swap is to use the transmission that is in the truck. It is the same as the car with the correct tail.
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
I did the opposite thing on an SM420. From torque tube to drive shaft. I was real easy. 4 four bolt change over. The seals fit and everything. Tail shaft did not change. I suspect the same will be true with the 3 speed. Just get the tail peice off the truck trany. I think when they went to the drive shaft in 55 they used the same tranny and just changed the tail piece. The tranmissions are identical otherwise. I had the advantage of finding a transmission guru who knew exactly what I wanted and had one in pile out back.
Where did all those guys go?
