3 members (2-Ton, 52Carl, 1 invisible),
94
Mod | | | Forums66 Topics128,211 Posts1,057,469 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2014 Posts: 3 'Bolter | | 'Bolter Joined: Mar 2014 Posts: 3 | I have a 48 3100 235 wt a 3 speed, I am going to a 1956 235 and 3 speed out of a belair. The 3 speed I have now is a torque tube set up and i am being told that the 235 wt 3 spd I am getting is not set up for a torque tube. Is there a conversion out there or an adaptor so I can use the set up I currently have with the new trans or do I swap trans. Thank you in advance Adam | | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | The easiest swap is to use the transmission that is in the truck. It is the same as the car with the correct tail.
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Apr 2008 Posts: 11 New Guy | | New Guy Joined: Apr 2008 Posts: 11 | I did the opposite thing on an SM420. From torque tube to drive shaft. I was real easy. 4 four bolt change over. The seals fit and everything. Tail shaft did not change. I suspect the same will be true with the 3 speed. Just get the tail peice off the truck trany. I think when they went to the drive shaft in 55 they used the same tranny and just changed the tail piece. The tranmissions are identical otherwise. I had the advantage of finding a transmission guru who knew exactly what I wanted and had one in pile out back.
Where did all those guys go?
