| | | Forums66 Topics128,087 Posts1,055,976 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 112 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 112 | I have searched and can not find the details to decode a 1949 gmc canadian 1 ton pickup (i think 1949). The tag is as follows
model 9434 s/n 994340307L engine x274433 body 2419 trim 394 paint 932
anyone have a location I can get info on this truck... or someone know what this data tells me about the truck?
Thanks for help...
Old Truck addict 1950 chevy 1 ton napco 1956 gmc 1 ton dually napco 1954 chevy 3/4 ton napco 1957 gmc civil defense napco panel
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Here is one source for your information. Old GMC Trucks.com | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy dirtball, your serial number breaks down as follows 9= year in your case 1949, confirm by body style 9434= GMC one ton on 137 inch wheelbase, left the factory as a pickup truck 0307L is the regular production number the original engine would have been a Chevrolet 216, hope that helps. | | | | | Joined: Feb 2012 Posts: 112 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 112 | That is exactly what I was looking for...thank you very much for your help... I have a 1950 chevy 1 ton already but couldnt find any info specifically to canadian versions
Did all the canadian gmc's use chevy motors? when did they switch (if ever) to the pontiac/gmc motors used in US versions?
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If you want to see some charts on the Canadian Specs with engine sizes, PM me an Email address. I have that information for the AD trucks | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy dirtball, Canadian GMCs that had a comparable Chevrolet model were powered by Chevrolet engines, this went on right up into the sixties, Canadian light duty GMCs never had the V6 engine they were powered by Chevy inline sixes and V8 engines. The larger Canadian GMCs were identical to their American cousins, hope that helps. | | | | | Joined: Feb 2012 Posts: 112 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 112 | Thanks for the help.. If canadian gmc's used chevy engines are the frames the samexas a chevy also... Do they have the gmc style front crossmember? Will a gmc motor bolt in or is it a swap like when you put a gmc in a chevy?
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | If you want to see some charts on the Canadian Specs with engine sizes, PM me an Email address. I have that information for the AD trucks Would the Canadian GMCs being discussed be AD (A-D, Advance Design) or ND (New Design)? | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy dirtball, the Canadian GMCs that had Chevy engines used frames that were the same as Chevrolet frames in all respects. If you want to install a GMC engine in a Canadian GMC that was originally powered by a Chevrolet, then you will have to make up some type of mount for the front of the engine, hope that helps. | | | | | Joined: Feb 2012 Posts: 112 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 112 | Thats exactly what i needed to mnow... Basically a chevy with gmc trim. I am dealing on a 49 gmc 1 ton pickup but needed to know my options .. Still dreaming of a AD 9 ft bed pickup with 302...
