| | | Forums66 Topics128,274 Posts1,058,436 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | Is the center bolt on a 54 3100/3600 5/16 or 3/8?
If it's 5/16, I just wasted $4.
Chris | | | | | Joined: Mar 2013 Posts: 165 Shop Shark | | Shop Shark Joined: Mar 2013 Posts: 165 | 5/16 on my 3100 not sure if you call it a true bolt as you cant put a wrench on the end as it is round so it sits down in the axle or your shims. the tension of the springs hold it tight while you tighten the nut. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | 1/2 inch pin on my aftermarket springs.
the axle must accept up to 1/2? | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | Crap! Well, I measured it with a caliper. It was pretty rusty. I thought it was 5/16 or 3/8. Guess I was wrong all the way around.
I bought some used springs due to the fact I had a broken main on one side. After I've ordered bushings, shackle rebuild kit and now, another set of center bolts.
I'm wondering why I just didn't buy new springs. | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | As it turns out they were the right ones. The U-bolts I ordered are about 3/4" longer. I'm pretty sure they'll work and have enough threads.
I used Denny Graham's method of spring bushing removal. It worked great, except for the last one. It turned out to be a multi-tool event.
Body say, die grinder, hammers, punches, screwdrivers, bench vise, electrical tape, and curse words.
| | | | | Joined: Mar 2008 Posts: 374 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 374 | Where might I find Denny Graham's method of bushing removal? Thanks! | | |
