6 members (greenie-reddy, tesa, Shade Baby, asilverblazer, wvstovebolt, 50Chevy3100), 88 guests, and 2 robots.
Topics128,083
Posts1,055,967
Members48,430
#1020106 04/07/2014 6:55 PM
Sorry to have to ask this, but I've never done this before and don't want to screw something up. I'm getting ready to remove my gas tank (38 half ton). Is it simply as easy as loosening the straps and disconnecting the fuel line and wire to the sending unit?
The tank is under the seat, and the back end of the tank tucks under the seat support. Not sure if the seat support needs to come out or not (looks like it might be welded in, so I doubt it needs to come out).
Also, I believe the bolts for the strap are under the cab at the rear of the tank. I started to soak the nuts and bolts there with PB Blaster before loosening them.
Thanks for any info.
1938 Chevy 1/2-ton
More info in the Gallery Forum
She looks good at 50 yards, and 35 miles per hour, on a dark night.
Hoff #1020109 04/07/2014 7:02 PM
I don't have a '38, but most early Chevy fuel tanks are removed as you suspect by unbolting the straps. I'll state the obvious:
Empty vented fuel tank. No heat on the bolts.
Drew
Hoff #1020126 04/07/2014 8:39 PM
i can help. what i did was this.
i removed the connection that goes out, the filler, this helps so it doenst get stuck, then i took off the line that goes to fuel pump, then i moved the two straps forward BUT be careful the tank might drop if its full, so i lower the tank, then jack up the truck and remove tank. i hope this helps
1937 Chevrolet Carryall http://www.oldmemoriescc.com/images/blvdbombs/images/IMG_6465_JPG.jpg
1937 1/2 ton (sold)
1938 1/2 ton (sold)
1939 1/2 ton (sold)
Phil 4:4
Hoff #1020174 04/08/2014 12:30 AM
back yard wrench turner
Yes you have the correct procedure. Just remember to remove the filler tube also.
oldmemories this tank is under the seat!
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
Hoff #1020233 04/08/2014 3:26 AM
Thanks for the advice. I hope to get to this over the weekend. I took the sending unit out and I have a half a tank of fuel to drain out.
1938 Chevy 1/2-ton
Hoff #1021238 04/12/2014 7:25 PM
I got the tank out today. Not too much of a job fortunately. Broke a bolt on one of the straps, but just a minor inconvenience.
After I got the tank out and emptied the residual gas, there was a lot of rust particles. It's probably best if I get a new tank, but I haven't found any for a 38 half ton. Any suggestions?
Thanks.
1938 Chevy 1/2-ton
Hoff #1021240 04/12/2014 7:42 PM
Radiator shops will clean them out and recoat the inside. I paid 250.00. On mine they cut the bottom out in three places sand blasted the inside rewelded the tank and coated it. It has been great since that was done.
Hoff #1021300 04/13/2014 2:24 AM
My radiator shop wouldn't do mine so I cleaned it good and used the POR15 sealing kit on my 37. Its been 15 years and its held up good. I think the kits are about $75 if you go that route. It took me and a nephew one afternoon to do it. Came out looking slick.
Hoff #1021305 04/13/2014 2:37 AM
I used Red-Kote four years ago.
Read about it.
Hoff #1022511 04/18/2014 1:36 AM
Well, I used the POR-15 tank cleaning kit today. I rinsed the tank out well first and tried to flush as much of the loose stuff out as possible. I then set up a sling to hang the tank from. This allowed me to move and flip the tank to try to get all internal surfaces with the cleaner, prep, and sealer. I used a lot of hot water to rinse, then dried it thoroughly with a hair drier. A little time consuming, but the areas that I could see with a flashlight got really clean looking, and seemed to be well coated with the sealer. Takes 4 days for the sealer to cure, and hopefully my new pads, straps, etc., will be in soon. Anxious to get it back on the road!
1938 Chevy 1/2-ton
