4 members (Otto Skorzeny, klhansen, Shaffer's1950, Steelonsteel), 101 guests, and 2 robots.
Topics128,113
Posts1,056,618
Members48,450
#101924 08/03/2007 3:10 AM
V
V Offline
i tried searching around for awhile and couldnt find a fix on here so ill ask
im about 99% done with my 48 loadmaster, i've done the breaks, body, exhaust, dump....but the last thing is probably very simple to someone that has experience and i just cant figure it out
my truck starts and runs great, it has a 12 volt bat, 12 starter (great find) and a new 12 volt GM alternator, i just cant get the batt to charge or the truck to run off the alternator, there were 2 wires attached to the old generator that i hooked up to almost identical locations on the alternator, it'll run for about 15-20 mins until it sucks the life from the battery....any ideas's
#101925 08/03/2007 3:49 AM
vonguinness,
I you want to call me at 518-732-7989 (Castleton), I would be pleased to either talk you through your wiring problem and/or come by and set up your wiring. Most likely it will be a simple matter of wiring your alternator through your ammeter to your battery (and bypassing the original voltage regulator).
Or, post here the year/brand/style of alternator and people will try to help you get this correctly wired.
Tim
lederman@siena.edu
#101927 08/03/2007 4:49 AM
Joe,
I didn't read the entire article you linked, but it should be noted that vonguinness has replaced a generator with a alternator. Without going into the gory details, the generator grounds the field to produce the charge while a alternator relies on power to the rotor to create a charge.
Stuart
#101929 08/03/2007 6:41 AM
Do I understand you correctly that you connected your alternator to the old generator regulator? If so, this is not correct as outlined above; wire around it completely.
Also, exactly what kind of 12v alternator do you have?
1960 GMC Panel w/ 305 V6, 4 Speed TV Repair Van "The Monitor Lizard"
1961 Chevy Apache 20 283, 4 Speed, Hydrovac
www.picturetrail.com/starchief
#101930 08/03/2007 3:10 PM
vonguinness,
If you look in the 'Tech-Tips' at the top of the page, there is a article in the electrical tips on converting a 6 volt generator/voltage regulator system to a 12 volt system using a SI alternator. There are some errors in the tech tip, but it will give you a general idea.
Stuart
#101931 08/03/2007 4:25 PM
V
V Offline
you guys are all fantastic, thanks so much....and to Tim, great to have someone so close buy, i actually grew up in kinderhook and live in albany now, so im just a stones throw away, ill try out a bunch of this stuff tonite and maybe be in touch over the weekend
and i have an alternator installed from a '71 chevy...just like the one in my c-10, its a pretty simple set-up, 2 pole
