3 members (klhansen, UtahYork, 1 invisible),
116
Mod | | | Forums66 Topics128,090 Posts1,056,374 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 12 New Guy | | New Guy Joined: Jan 2007 Posts: 12 | i tried searching around for awhile and couldnt find a fix on here so ill ask
im about 99% done with my 48 loadmaster, i've done the breaks, body, exhaust, dump....but the last thing is probably very simple to someone that has experience and i just cant figure it out
my truck starts and runs great, it has a 12 volt bat, 12 starter (great find) and a new 12 volt GM alternator, i just cant get the batt to charge or the truck to run off the alternator, there were 2 wires attached to the old generator that i hooked up to almost identical locations on the alternator, it'll run for about 15-20 mins until it sucks the life from the battery....any ideas's | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | vonguinness, I you want to call me at 518-732-7989 (Castleton), I would be pleased to either talk you through your wiring problem and/or come by and set up your wiring. Most likely it will be a simple matter of wiring your alternator through your ammeter to your battery (and bypassing the original voltage regulator). Or, post here the year/brand/style of alternator and people will try to help you get this correctly wired. Tim lederman@siena.edu | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Joe,
I didn't read the entire article you linked, but it should be noted that vonguinness has replaced a generator with a alternator. Without going into the gory details, the generator grounds the field to produce the charge while a alternator relies on power to the rotor to create a charge.
Stuart | | | | | Joined: Jun 2007 Posts: 90 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 90 | Do I understand you correctly that you connected your alternator to the old generator regulator? If so, this is not correct as outlined above; wire around it completely.
Also, exactly what kind of 12v alternator do you have? | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | vonguinness,
If you look in the 'Tech-Tips' at the top of the page, there is a article in the electrical tips on converting a 6 volt generator/voltage regulator system to a 12 volt system using a SI alternator. There are some errors in the tech tip, but it will give you a general idea.
Stuart | | | | | Joined: Jan 2007 Posts: 12 New Guy | | New Guy Joined: Jan 2007 Posts: 12 | you guys are all fantastic, thanks so much....and to Tim, great to have someone so close buy, i actually grew up in kinderhook and live in albany now, so im just a stones throw away, ill try out a bunch of this stuff tonite and maybe be in touch over the weekend J
and i have an alternator installed from a '71 chevy...just like the one in my c-10, its a pretty simple set-up, 2 pole | | |
