0 members (),
82
Mod | | | Forums66 Topics128,090 Posts1,056,378 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2012 Posts: 60 'Bolter | | 'Bolter Joined: May 2012 Posts: 60 | Just about have the engine completely rebuilt in my 1959 3600 and getting ready to drop it in the truck. this is my first attempt at this and I'm learning a lot. I've been researching new motor mounts and I'm very confused. All the online parts houses show front mounts that are side mounted. My truck has a single mount in front in the center of the cross member. My engine doesn't even have a place to mount brackets for the side mounted mounts. Why am I having trouble finding my mount and where can I find a replacement?
Proud of my taskforce! 1959 3600 long-bed. the ultimate work truck!
Rick Restivo Valley Center, CA.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Wait to hear from someone with first-hand experience with 58/58 motor mounts.
My guess, from reading similar posts, is that you have a 1958(and earlier)-style front motor mount (not the 1959 and later style front side motor mounts).
This oddity is not uncommon when there is a change in features. The assembly plants used up old parts before switching to a newer style part.
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | 1959 should mount on the front side. See Picture If you have a 1960-62 engine it will not have the provisions for these mounts. If that is the case you will have to adapt some other style of mounting.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Maybe the 47-54 front mounts would work nicely? | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | There was someone here recently that adapted the 1932-54 mount on a later truck.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | I do not know what I am talking about, but seems to me the front motor mounts for the AD would mean drilling two holes in the frame and calling it a day? Wouldn't we prefer to address this issue with a definitive solution if all it means is drilling a few holes?
Maybe its more than that, but hopefully we can give advice to those who need it. What about a paper drill template? I can do that. Must be more to it. | | | | | Joined: May 2012 Posts: 60 'Bolter | | 'Bolter Joined: May 2012 Posts: 60 | Thanks for the reply, That could definitely explain this. I'll look for mounts on earlier trucks.
Rick -
| | | | | Joined: May 2012 Posts: 60 'Bolter | | 'Bolter Joined: May 2012 Posts: 60 | Thanks the pics everybody sent. Your pics, along with the posts got me thinking that maybe I don't actually have a '59 engine. I reviewed the casting numbers and sure enough, it's a 60-62 235. This explains why I have so many holes in the front cross-member. Now that that I know what I'm looking for I should be all set. Wish I would have come here along time ago.. Rick -
| | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | The mounts are on the front of the engine. There are also two different lengths of mounts for 6 or 8 cylinder. See LMC catalog for diagram; http://lmctruck.com/icatalog/ca/full.aspx?Page=77 | | |
